Thread: 4th gear slipping
Results 1 to 3 of 3
  1. #1 4th gear slipping
    La Marque, Tx.
    I have a 2000 gp 3800 stock with 145,000 miles. The tranny shifts good all the way to 4th gear, after warming up it slips in 4th gear and also a noticeable whine. the trans appears to be full with no leaks however its very hard to tell on the dipstick on the level. it is not black, but not really red? It appears to be really thin and hard to tell the level. If you shift it back to third it does ok. I guess I'm asking is it worth having it drained with one of those newer machines that replaces all of the fluid and maybe adding a quart of Lucas oil or just drag it
    to the the tranny shop and see whats going on. I really hate to sink a bunch of money into it, as you never know whats next.
    Thanks for any help or comments.
    Larry
  2. #2 Re: 4th gear slipping
    GTX Level Member cerick08GP's Avatar
    Unfortunately your tranny needs a rebuild, your 4th gear clutch hub is toast. It going bad is independent of your fluid condition. The new hubs are hardened to prevent this.
    You will be able to drive a while like this (sans 4th gear), but be assured you are on bowered time. Your looking at about a 1k repair bill, changing your fluid or adding Lucas won’t help at all at this point.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: 4th gear slipping
    La Marque, Tx.
    Yeah, Its kinda what I figured but I was wishing something more easy on the pocket book.
    Thanks
    Larry
  1. 4th gear slipping
    By RickA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-20-2010, 06:02 PM
  2. Transmission slipping/hunting for gear?
    By The Chad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-01-2009, 11:44 AM
  3. 99 regal gs.. slipping in OD
    By GnArKiLL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-08-2009, 12:27 AM
  4. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
  5. Transmission slipping?
    By WGPGT00 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-04-2008, 07:27 AM
