Thread: Shifting Problem
Results 1 to 4 of 4
  1. #1 Shifting Problem
    Ocoee, Florida
    My 2000 GT all of a sudden will not shift into overdrive. Fluid is full, red and not burnt smelling. 1st, 2nd and 3rd feel okay, it just stays in 3rd gear and won't even attempt to go into overdrive. My TPS readings are good (.70 volt at idle to 5.0 at WOT). Any ideas as to what my problem is ??
    Thanks, Skip
  2. #2 Re: Shifting Problem
    SE Level Member Nsane's Avatar
    Feb 2010
    Rochester,NY
    how many miles are on you car
  3. #3 Re: Shifting Problem
    Ocoee, Florida
  4. #4 Re: Shifting Problem
    You most likely have the standard worn out/stripped 4th clutch hub. Very common in our transmissions and while it doesn't "hurt" the tranmission overall. You don't have 4th gear.
  1. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  2. shifting from first to second
    By zuk7 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 05-24-2010, 08:09 PM
  3. Shifting problem, pls help
    By mtrmes02 in forum General Tech Discussion
    Last Post: 01-23-2010, 09:07 PM
  4. better shifting?
    By nicksilvergt99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2009, 11:19 PM
  5. Shifting 1,2,3 before 20 mph!!
    By fratzke7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-30-2008, 06:22 PM
