Thread: How To Remove Transmission Help!
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 75
  1. #1 How To Remove Transmission Help!
    SE Level Member Hixc's Avatar
    Lawrence MA
    i have a 98 grand prix gtp that needs to have the torque converter replaced. what tools do i need to do this. Also a how to guide with detailed steps would be awsome, since this is my first big project. What size Socket do i need for the Axle Nuts? how does the axle spindles discconect from the tranny? also how do i unbolt the steering gear from the cradle. Thanks!
  2. #2 Re: How To Remove Transmission Help!
    Flat head screw driver
    Philllips screwdriver
    13mm wrench
    18mm wrench
    8mm socket (all sockets deep unless stated)
    10mm socket
    13mm socket
    15mm socket
    18mm deep and shallow sockets
    34/36mm sockets
    24-48" of extensions
    Needle nose pliers
    3-4 foot 4x4 and 4 feet of chain or engine holder with accessories
    push pin clip popper always good to have.
    Jackstands and jack
    Disconnect negative battery cable
    Pop shifter cable off of selector arm
    Unplug 2 connectors at trans range position switch (97-99ish)
    Remove 2 13mm bolts holding shifter cable bracket to trans (keep cable in bracket)
    Remove 15mm nut on from lower trans to engine bolt location to remove negative cable from that stud.
    Support engine with fixture or 4x4 and chain (Make sure this is well done and it's taunt, your life will rely on it)
    Jack the car pretty high and support from drip edge (factory jacking location in front along door sill)
    Drain trans fluid (10mm)
    Remove both front tires (19mm)
    Remove splash shields that keep you from seeing trans/engine (phillips/pop clips)
    Remove cotter pins from ball joints
    Remove ball joint castle nuts (18mm)
    Remove the two bolts (18mm both sides) that hold the ps rack to the subframe
    Remove both sway bar end links (stock 13mm)
    Disconnect ABS sensors from wiring
    Remove 10mm bolt that holds brake line bracket to body in wheel well
    Remove both axle nuts (stock 36mm, aftermarket typically 34mm)
    Leaving axle nut on end of spline hit (to not mess up threads) the axle inward until it's freed from the hub and moving
    Using a long prybar have an assistant pry down on the lower control arm while you hit the balljoint to free it from the knuckle
    Remove both axles from hubs
    Remove axles from trans
    Remove any clips holding ps lines, wires, abs sensor wiring etc to subframe
    Remove 4 18mm bolts holding subframe to body, slide out of way
    Remove starter plastic shroud (POS in way of bolts (10mm)
    Remove starter (2 15mm bolts, then wiring held on by 8mm and 13mm)
    Remove plastic flywheel shield (10mm)
    Remove 3 flex to torque converter bolts (18mm) you can turn flywheel with screwdriver
    At passenger wheel area:
    Disconnect VSS sensor on diff cover of trans
    Remove trans to engine diff bracket (4 13mm)
    Use extenions and deep 18mm socket to remove bolt that goes from engine into trans on the back of the engine.
    Support trans from below with trans jack/atv jack etc
    Remove 4 (18mm) bolts holding trans to engine from above
    Pry trans off engine and lower
    When trans is down, remove 1 10mm bolt holding dipstick tube in trans and pull tube out.
    Slide trans out
    Reverse for install
    Tons of pics about axle pulling/balljoint etc and stuff in my photobucket account.
    Psd: Boosted
  3. #3 Re: How To Remove Transmission Help!
    Lawrence MA
    Thanks I Appreciate This!
  4. #4 Re: How To Remove Transmission Help!
    Does it still drive, you aren't that far from me.
  5. #5 Re: How To Remove Transmission Help!
    Lawrence MA
    no i just has a mechanic put the new tranny in from a swap, he put in the broken torque converter and just put the whole car back together. now im out 350$. i was going to attempt this myself tonite.
  6. #6 Re: How To Remove Transmission Help!
    Jul 2008
    sumter,south carolina
    bill, thats an awesome writeup... should be stickied.
    02 GTP with mods 05 GP for DD
  7. #7 Re: How To Remove Transmission Help!
    How bad is the torque converter? If it's torn up inside it might be spewing junk into the valve body.
    On th sticky suggestion, I guess we would mention it to Bio?
  8. #8 Re: How To Remove Transmission Help!
    Lawrence MA
    The torque converter has a broken missing weight. so there are only 2 of the 3 on it atm. i havnt even bothered starting the car since the swap. i figure it would be a bad idea. i have a question on holding the engine. i have a 4x4 piece of wood going across the whole engine. do i just need to tie a chain around the engine to the wood to keep the engine from moving? or do i need to lower the engine to unbolt the tranny.
  9. #9 Re: How To Remove Transmission Help!
    I put the 4x4 across, run a chain to both engine pull brackets over the 4x4 and then use some 2x4 or small stock to take the slack out of the chain. The trans comes off after the engine/trans is supported by the 4x4 w/o having to lower the motor at all.
  10. #10 Re: How To Remove Transmission Help!
    Jul 2008
    BIOOOOOOOOOOOO sticky bills writeup
  11. #11 Re: How To Remove Transmission Help!
    Lawrence MA
    So the 4x4 i used snapped and the engine almost hit the ground :O. i resupported it with a cumalong. i just took the cradle off the car. what would be my next step?
  12. #12 Re: How To Remove Transmission Help!
    Stop listening to me if you snapped a 4x4. I've seen a 2x4 used, always use 4x4's myself and can't imagine how you can snap a 4x4 with less than 1,000lbs of weight on it. Were you supporting the motor or the whole car?
    What do you mean, what's your next step? I posted pictures and text saying what should be done to lower a motor and swap a converter. Somehow you already did the impossible.
    Was this 4x4 older than you? How in the holy hell did you snap a 4x4 when it's supporting a motor/trans?
  13. #13 Re: How To Remove Transmission Help!
    Jul 2008
    4x4 must have been infested with termites.
  14. #14 Re: How To Remove Transmission Help!
    Nov 2009
    Grand haven
    lol ^^^
  15. #15 Re: How To Remove Transmission Help!
    Clinton, MI
    Hey there.. I'm new to this forum and am contemplating getting a 2004 or newer Grand prix. I read the trans removal write-up and it is excellent. I've always owned Fords and they have to have the engine/trans removed as assemblies with the subframe. My question is the transmissions on these cars can be removed without a hoist and the engine can be left in the car?
    Thanks.
  16. #16 Re: How To Remove Transmission Help!
    Jul 2008
    u have to brace the motor... trans comes out from underneath pretty easy.
  17. #17 Re: How To Remove Transmission Help!
    Portland Oregon
    I found it WAY easier to pull the motor and swap the torque converter that way.
  18. #18 Re: How To Remove Transmission Help!
    Jul 2008
    ^ if u dont have a lift
  19. #19 Re: How To Remove Transmission Help!
    SE Level Member robstout's Avatar
    cincinnati, oh
    Is there anyway to get the bolt that goes in backwards from engine to trans while it is still in the car? Its the one you show the pic of the impact and long extension. Also the bracket that holds trans to engine i removed the 2 bolts on trans but is it necessary to remove the 2 on the engine also?? Any help would be greatly appreciated as i have the cradle and everything laying on the floor....
    Shake-N-Bake!!
  20. #20 Re: How To Remove Transmission Help!
    Charles City, IA
    Why did you drop the cradle>? Pulling it out the top is way easier. Yes you have to unbolt that bracket from the engine and then that will allow you to go threw the passenger wheel well with long extensions and get the bolt out.
    SMGPFC Two Nipple General
  1. How TO REMOVE OIL PAN??
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-11-2009, 10:37 PM
  2. how to remove a 97 gp transmission?
    By 1997gp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 12:10 AM
  3. how to remove a 97 gp transmission?
    By 1997gp in forum General Tech Discussion
    Last Post: 07-07-2009, 11:26 AM
  4. Remove cat.
    By bowtechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2009, 02:43 PM
  5. how do i remove the transmission
    By EMerola in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 12-09-2008, 07:28 PM
