Thread: Tranny help!
Results 1 to 14 of 14
  1. #1 Tranny help!
    GT Level Member macey43's Avatar
    Jul 2010
    salisbury, MA
    ok guys, my grand prix has 71k miles on it and has never had issues before (it's also an automatic 2002 gt). All of a sudden when i was driving home today i was doing about 30 and when i gave it gas it just didn't shift and my rpms just kept going up. I took my foot off the gas and it shifted. Thinking i was just being paranoid i tried accelerating again... this time the tranny made a clicking noise. Recently ive installed a stereo, HUD, front and rear speakers, and wired a 3 plug thing into the power drop. Is it possible that any of these could be messing up the computer or something? What else could it be?
    sig too tall
  2. #2 Re: Tranny help!
    Jul 2008
    sumter,south carolina
    3 plug thing? check ur fluid level... with car running at operating temp.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Tranny help!
    Jul 2010
    salisbury, MA
    Haha I was in a rush it's like 3 cigarette plugs and a USB port that plugs into a cig lighter. I cut off the end and hardwired it. The fluid level is fine and it's all of a sudden working so I think it is electrical
    sig too tall
  4. #4 Re: Tranny help!
    Jul 2008
    i doubt that would have anything to do with it. could be a number of things. get it scanned at a reputable shop. even if check engine light isnt on. codes can still be in the PCM and not set off light with trans issues. could need a filter, solenoid, etc etc.
  5. #5 Re: Tranny help!
    Jul 2010
    salisbury, MA
    Ok thanks and no there were no lights
    sig too tall
  6. #6 Re: Tranny help!
    Jul 2010
    Manitoba
    get it scanned but i have seen a bad tps sensor cause this
  7. #7 Re: Tranny help!
    Jul 2008
    Quote Originally Posted by peppy View Post
    this is true,which a vacuum leak could cause TPS issues.
  8. #8 Re: Tranny help!
    Vacuum leaks won't cause a position sensor to read incorrectly.
  9. #9 Re: Tranny help!
    Jul 2008
    go pull ut t boot off intake and see if it doesnt pull a TPS code. i know, ive experienced a few times.
  10. #10 Re: Tranny help!
    Jul 2010
    salisbury, MA
    I was thinking it was the tps also but I got it scanned and although he couldn't tell if it was in the right range the tps was definitley responding correctly. I talked to a gm tech and he said it could be an airflow problem so I am going to check the maf
    sig too tall
  11. #11 Re: Tranny help!
    Jul 2010
    salisbury, MA
    And as a follow up to my first post. The symptoms kind of change with the day and is why I'm thinking it's some sort of sensor issue. When I give the car a little gas it will go smooth for the most part and other times the rpms will wobble then shift. I'm I gun it instead of down shifting and taking off, it stays in the same gear, sounds boggy, and of course not take off.
    sig too tall
  12. #12 Re: Tranny help!
    Jul 2010
    Manitoba
    i seem to remember something about a tsb concerning driveability problems but mainly with an aftermarket air filter (oil from the filter getting on the maf sensor) so it wouldn't hurt to clean the maf sensor
  13. #13 Re: Tranny help!
    Jul 2010
    salisbury, MA
    Ok I'll have to try that. And for the first time I can say I am very happy that the chEck engine light has come on so I can get it scanned in the am.
    sig too tall
  14. #14 Re: Tranny help!
    Jul 2010
    salisbury, MA
    i cleaned the maf sensor and it runs a little better but still not back to normal. im sure cleaning it would have improved performance even if the car was normal. Also i got the car scanned and came up with a po410 code... secondary air injection fault. I was thinking the air pump... but how could that hurt my performance this bad? maybe a clogged cat?
    sig too tall
  1. Tranny and the PCM
    By offroadfury6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2009, 10:29 PM
  2. Is my tranny going??
    By 98gpgt98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2009, 10:35 PM
  3. tranny
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 01:01 AM
  4. FWD 3.8l to RWD tranny
    By static2489 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2008, 02:26 PM
