Thread: chain decision
Results 1 to 8 of 8
  1. #1 chain decision
    i just had my gtp turbo dynoed at zzp it put down 409whp at 18psi or so im getting ready to upgrade my tranny and im thinking of going with daves 7/8 chain just wondering if you gys think that would hold.
    i do run the car at the track as much ass i can 4-5 times a year and i do yous slicks
  2. #2 Re: chain decision
    Barksdale AFB, LA
    I can't believe the stock chains are holding up to 409WHP. Nice!
    2009 Subaru Impreza WRX STI
  3. #3 Re: chain decision
    Moore, Oklahoma
    Do it right the first time... get the 1" no questions. Many turbo cars similar to yours have busted 7/8" chains in a short amount of time. I wouldn't even consider a 7/8" chain if I were in your shoes.
    Shawn W. Larsen
  4. #4 Re: chain decision
    Quote Originally Posted by Iron Indian View Post
    yea i know your right i was just trying to cheap out 300 7/8 850 gm 1in
    i talked to dave and he told me that non of his customers have broke his 7/8 chain that he knows of
  5. #5 Re: chain decision
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    You are making enough power to put the 7/8" chain into the questionable area. What gear ratio do you have? That makes a differences as well.... Also what torque converter? How hard is the 1-2 shift?
  6. #6 Re: chain decision
    Quote Originally Posted by Trannyman95 View Post
    2.92 stock gtp converter 1-2 shift is getting soft
    i would like to stay with my 2.92 gears = i cant with the gm 1in
    i have a zzp 3k stall for the new tranny and 4340 input shaft
  7. #7 Re: chain decision
    Fort Wayne, IN
    With 2.93s you should be ok with the 7/8 chain, and having a looser converter helps as well as it takes shock off of the parts and gives you a little more cushion.
  8. #8 Re: chain decision
    Moore, Oklahoma
    Interesting info Trannyman, I did not know that. I learned something
    Shawn W. Larsen
  1. First mod decision
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2008, 10:06 PM
  2. Which timing chain?
    By whitcomb in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-01-2008, 04:49 PM
  3. gm 1 in chain
    By kevlws23 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2008, 01:36 AM
