Thread: Going to install a transmission cooler tomorrow, have some questions.
Results 1 to 10 of 10
  1. #1 Going to install a transmission cooler tomorrow, have some questions.
    Canada
    i have a 98 GP GT couple with 111k mile on it. since the transmission shifts harsh when the coolant head to 210, i am going to install a transmission cooler tomorrow. It is a B&M 70268 supercooler. now i have some questions.
    1. what is the fitting size on 98 model? 1/4, 3/8 or 5/8?
    2. which one is the ATF return line? how to determine? any pics?
    3. is the bypass necessary? i live in vancouver, BC, Canada.
    Any tips will be appreciated, too.
    Thx a lot, guys.
    Any i will upload pics after i finish. lol
  2. #2 Re: Going to install a transmission cooler tomorrow, have some questions.
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    You will find most guys say to run a 180 degree thermostat and you don't need a cooler. Just another thing to leak. Many guys who drag race these cars say the temp never goes over 180 degrees on their hard runs. I think I will be installing one this summer but only because I plan on going to Track day at Limerock and am a little concerned that that kind of constant strain will increase the temps.
    For street duty just lower your thermostat temp to 180. It will save you money, and busted nuckles
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  3. #3 Re: Going to install a transmission cooler tomorrow, have some questions.
    If your engine coolant is 210, your tranny temp is higher if the car is warmed up.
    If you beat on it on the street as well, it might be a good idea.
  4. #4 Re: Going to install a transmission cooler tomorrow, have some questions.
    Jersey
    i have the "desert fox" kit, it uses a b&m cooler, works amazing. It sucks in winter because it will take forever for trans to warm up to get t/c lockup.
    16' wrx sti- stock
  5. #5 Re: Going to install a transmission cooler tomorrow, have some questions.
    Canada
    Quote Originally Posted by MBruneaux View Post
    Thx. I used to have 180 therm, but it didn't work well in winter, so i switched it back to 192F. I ordered one cooler from local part store today. it was 76 bucks plus tax. i found from summitracing.com it is only 50 bucks shipped. What the hell of the price here in Canada.
  6. #6 Re: Going to install a transmission cooler tomorrow, have some questions.
    Canada
    Quote Originally Posted by 99prixgt View Post
    Thats awesome, but Vancouver is kinda of cold in winter.
    Could u please tell me which line is the return line and which one is the feed line? Thx. BTW: what did u use to cut the hose? and what the meaning of T/C lock up? Thx alot.
  7. #7 Re: Going to install a transmission cooler tomorrow, have some questions.
    Canterbury, CT
  8. #8 Re: Going to install a transmission cooler tomorrow, have some questions.
    I've been a fan of the 1+ inch rad solution.
    http://www.grandprixforums.net/radiator_upgrade.php
  9. #9 Re: Going to install a transmission cooler tomorrow, have some questions.
    Athens, OH
    I just put a cooler on my GP. The top outlet in the radiator is the return line.
  10. #10 Re: Going to install a transmission cooler tomorrow, have some questions.
    Athens, OH
    Make sure to flair the ends of the cut line slightly though! The pressure can get up to 50 or so PSI according to a local Chevy dealer.
  1. Transmission cooler setup - should I change it? What temps are too hot?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-28-2017, 08:25 AM
  2. transmission oil cooler
    By 03buickregalls in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 09:11 PM
  3. Transmission Cooler Lines
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-01-2010, 08:53 AM
  4. Auxillary transmission cooler?
    By keenan00gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2008, 06:35 PM
  5. Transmission questions.
    By ChvyTrcksFrdScks in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2008, 07:11 PM
