Thread: What will my final drive ratio be?
Results 1 to 14 of 14
  1. #1 What will my final drive ratio be?
    Feb 2008
    I'm grabbing a trans from a 98 NA Regal. I know the final drive as-is is 3.05:1 What will it be if I replace the differential with my stock HD one? 3.29:1?
  2. #2 Re: What will my final drive ratio be?
    Portland Oregon
    You are correct. By replacing with your HD diff you will have a 3.29 fdr. With grand prix's it's easy, you either have 2.93 or 3.29 based on the sprockets on the drive chain. With regals and impala's they have the same 1:1 ratio sprockets as grand prix gt's but they use a diff with a different size sun and planetary gears to get 3.05
  3. #3 Re: What will my final drive ratio be?
    Banned - Busted For Scamming
    Feb 2009
    Make sure to get the sun gear!!
  4. #4 Re: What will my final drive ratio be?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Take everything related to the final drive, including the output shaft. The 97s are different than 98+.
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: What will my final drive ratio be?
    Feb 2009
    Really? Whats the difference?
  6. #6 Re: What will my final drive ratio be?
    Portland Oregon
    97's have a c-clip that actually holds the diff in place. Not sure it that makes the output shaft different.
  7. #7 Re: What will my final drive ratio be?
    Feb 2009
    So does my 99
  8. #8 Re: What will my final drive ratio be?
    Portland Oregon
    There are two types of clips, one that requires the diff be popped off the output shaft like an axle out of the tranny (98-08), and a c-clip that must be removed first to pull the diff off the output shaft (97)
  9. #9 Re: What will my final drive ratio be?
    Feb 2008
    As in pick up a new one?
  10. #10 Re: What will my final drive ratio be?
    Feb 2008
    Quote Originally Posted by OH4CompG View Post
    I'll remember that when I pull mine out.
    Thank you guys for the extra info, BTW! FEED ME MORE!!!!
  11. #11 Re: What will my final drive ratio be?
    Portland Oregon
    Quote Originally Posted by DanGTP View Post
    He means if you're getting the HD diff make sure it comes with a sun gear because Its a different size then the one you have.
  12. #12 Re: What will my final drive ratio be?
    Feb 2008
    I'm not getting another one. I'm re-using my stock one. Will that be an issue?
  13. #13 Re: What will my final drive ratio be?
    Feb 2009
    No. I was saying that you need to use the 3.29 sun gear, not the regals 3.05 sun gear, that is all lol
  14. #14 Re: What will my final drive ratio be?
    Feb 2008
    Ah. Will do.
  1. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
  2. final opinions
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-30-2009, 08:37 AM
  3. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
  4. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
  5. Changing internal gearing? (not final drive)
    By Ron Vogel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 02:27 AM
