Thread: help i need a spec
Results 1 to 9 of 9
  1. #1 help i need a spec
    May 2008
    McHenry IL
    anyone have clearance specs for 4t65e input clutch pack?
  2. #2 Re: help i need a spec
    May 2008
    McHenry IL
    anybody?????
  3. #3 Re: help i need a spec
    May 2008
    McHenry IL
  4. #4 Re: help i need a spec
    Donating Users nvsridez's Avatar
    sw WI
    I searched for 20 minutes for ya...This is the only info i can find:
    http://www.intense-racing.com/docs/I...structions.pdf
    EDIT: Sorry...That's shift pack.....No luck bro. Try emailing intense or zzp?
  5. #5 Re: help i need a spec
    Banned - Busted For Scamming
    Feb 2009
    Gm doesn't use clutch pack clearances, install the correct amount of frictions and steels and you are good to go.
  6. #6 Re: help i need a spec
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Quote Originally Posted by GTPJOE90 View Post
    General rule is .008-.012 of clearance per friction. So if the input clutch pack has 4 frictions, you want their to be .032-.048 clearance. You can adjust this pack by getting a thicker snap ring if its a bit on the loose side. I personally run 5 frictions in my input clutch pack with thinner steels which are .050 instead of the stock .076.
    For 2nd you can run the stock clutch pack tolerance but sub 2 of the standard .068 steels for 2 of the .090 steels.
    For 3rd I run the stock raybestos z-pack
    4th stock stack up as well.
    I run all raybestos performance stage 1 (red) frictions for 1st, 2nd, 4th, which are great for higher torque/hp applications and still good for DD which is what I use my car for.
    You'll want to mod your spacer plate too if your panning on pushing some major power
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  7. #7 Re: help i need a spec
    Schaumburg, IL
    If your making any type of power your 3rd gear with standard clutch pack configuration, it will hate you.
  8. #8 Re: help i need a spec
    Feb 2009
    Yea i know.
  9. #9 Re: help i need a spec
    May 2008
    McHenry IL
    i figured i was good to go..... god damn it... thanks guys
  1. Spec-V
    By CTKGP09 in forum Track Sessions and Kills
    Last Post: 08-13-2009, 09:50 PM
  2. 98 GTP VS 03 Spec R Sentra
    By KawaFord in forum Track Sessions and Kills
    Last Post: 08-08-2009, 01:41 PM
  3. spec v, and scion tc
    By BIGTMANE in forum Track Sessions and Kills
    Last Post: 06-16-2009, 06:59 PM
  4. Rim Spec for 2001 Grand Prix SE
    By ricez in forum Tires & Wheels
    Last Post: 07-30-2008, 08:30 AM
