Thread: comp g trans 3.29 ratio (FR9)
Results 1 to 5 of 5
  1. #1 comp g trans 3.29 ratio (FR9)
    SE Level Member 04GTPCOMPG's Avatar
    Apr 2009
    MA
    what other car models should I be looking at that have an "FR9" trans other than other 04/05 comp g's...just trying to find a low mileage replacement thank in advance
  2. #2 Re: comp g trans 3.29 ratio (FR9)
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The Comp G trans was the only tapshift 3.29 ratio transmission that will work with a 3800. The only other tapshift specific transmissions that GM used were in the LS4 GXPs but the trans case is different for the V8s
  3. #3 Re: comp g trans 3.29 ratio (FR9)
    GT Level Member BoostedComp's Avatar
    Youngstown
    hey trannyman is their a price difference on your "standard" build transmission for the compgs compared to other grand prixs? im just talkin about the basic street built tranny... not like a crazy hyped up transmission.
  4. #4 Re: comp g trans 3.29 ratio (FR9)
    Fort Wayne, IN
    The rebuild costs apply across the board for the most part. My base High Perf street/strip rebuild is what I suggest as a starting point for all supercharged cars while the standard rebuild option I offer is suited to NA cars in stock configuration. About the only variation in cost for the base performance rebuilds would be the core fee from tapshift to non tapshift and that would only apply if you dont send your existing transmission in to rebuild.
  5. #5 Re: comp g trans 3.29 ratio (FR9)
    Apr 2009
    MA
    Trannyman...pm sent
  1. Air Fuel Ratio
    By rolyat in forum General Tech Discussion
    Last Post: 01-12-2010, 08:17 AM
  2. 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    By GrandPrixGT300 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-07-2009, 12:42 PM
  3. what is my differential ratio, and first gear ratio?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-07-2008, 09:31 AM
