Thread: 4t65E replacing 4t65e-hd question
Results 1 to 3 of 3
  1. #1 4t65E replacing 4t65e-hd question
    utah
    So yea, About 6 months ago I did a swap at a local shop and had them rebuild a 4t65e engine. I put it in my 99 GTP and it runs fine, just shifts ultra hard...Sometimes it sticks in 3rd gear when on the highway before doing a late shift into 4th...Ive read that the final drive ratios are different 2.93 hd, 3.29 for non hd...now my question is should I reprogram the ecm for that variable or are there other things that should be set...and also would it be the main computer or the transmission computer (the guy at this one shop said my car had one?)
  2. #2 Re: 4t65E replacing 4t65e-hd question
    Wooster, Ohio
    umm, not sure on a whole lot on trans, but the PCM controls the trans, i do believe you would need a tune for the GTP trans, do some searching, sure someones ran into this. you could just do a out of the box tune from Intense but the shifts are controlled by two solonoids, a 1-2 and a 3-4 solonoid, and they shift when told to basically.
    edit- Trannyman95 is your guy on trans problems, this is Dave from Triple Edge Performance, although i sent him a PM about a week ago about a trans problem and have never heard back, so you can try your luck
  3. #3 Re: 4t65E replacing 4t65e-hd question
    utah
    True...Dave helped me out a ton last year when the differential went down on my car. Im just stumped at the moment.
  1. Have a 4T65E Question? Please Read! Triple Edge contact info
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2023, 02:22 AM
  2. 4t65e HD Rebuild (Question is for Trannyman95 or any other Tranny GURU)
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2013, 01:24 PM
  3. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
  4. 4T65E-HD Question...
    By WHT98GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-10-2009, 04:53 PM
  5. 4T65E HD tranny swap and perf. shift question
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 11:49 AM
