Thread: first gear slips/shudders under moderate acceleration
Results 1 to 3 of 3
  1. #1 first gear slips/shudders under moderate acceleration
    SE Level Member almighty's Avatar
    northern illinois
    first gear shudders/slips under moderate acceleration but not when i light foot it, or slam on the gas, unfortunately slamming on the gas spins the tires and feels a bit like a "neutral drop" and i dont wanna break anything. As far as i have scanned i dont have any tranny codes, unless my scanner just doesn't see them. all other gears are good and solid and seem to shift nicely. fluid levels are good. and this happens a bit more when warm but is fairly consistent. any advice would be appreciated.
  2. #2 Re: first gear slips/shudders under moderate acceleration
    jaipur, india
    it might be the clutch
  3. #3 Re: first gear slips/shudders under moderate acceleration
    northern illinois
    yeah its possible, but like i said, if i go light on the throttle i get nothing, if i gun it i get wheel spin, but if im just doing normal acceleration it shudders from about 5mph to 17ish then its good, i can have the throttle anywhere i want in first 1st with no shudder or issues, its only moderate acceleration from 5-17ish mph that it will do this, at any time if i let off the throttle or hit it harder it stops.
  1. Transmission slips bad at WOT
    By Rather B Blown in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-13-2009, 07:08 AM
  2. Car "shuttering" under moderate boost?
    By CDoran in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:25 PM
  3. time slips
    By justwhisen in forum Forum Bugs/Suggestions
    Last Post: 05-14-2009, 11:07 PM
  4. No 4th gear & slips/shacks at take off!
    By Stover in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2008, 12:13 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
