Thread: comp g transmission
Results 1 to 19 of 19
  1. #1 comp g transmission
    SE Level Member 97grandprix's Avatar
    grand rapids, mi
    does anyone know if the comp g transmission will fit on my 97 GT.....im thinking of doin the top swap and i need a stronger transmission...i figure that the comp G would be great if it will fit.....i know where i can get one for about $800 if it will fit.
  2. #2 Re: comp g transmission
    GT Level Member BoostedComp's Avatar
    Youngstown
    its not really stronger... its the same hd tranny that is in all other gtps. it does have 3.29 gears though. and the part that is hardened in the gtp tranny isnt one that tends to break. At least from what i have been told. and thinkin more about it, the comp g tranny's have manual valve bodies in order to work with tapshift, so im pretty sure they arent compatible anyway.
  3. #3 Re: comp g transmission
    grand rapids, mi
    what about the 5 speeds from the older GP. will that work with a top swap?
  4. #4 Re: comp g transmission
    Youngstown
    a few people have matted a five speed to the newer styles... but its a ton of custom fabbing and im not sure which tranny they used
  5. #5 Re: comp g transmission
    grand rapids, mi
    what one would u recomend is the best for the top swap? im not trying to have a real fast car. i just want something with a little more power than what i have. im still going to be using it a daily driver.
  6. #6 Re: comp g transmission
    CT
    How is your transmission now? I mean if its not doing bad then I say throw a shift kit in it and change the fluid. GTP transmissions have 2.93 gears so you'd need to swap your 3.29's or purchase a new set. I say stick with what you got if it not broken.
  7. #7 Re: comp g transmission
    grand rapids, mi
    my transmission works great....my car is is top running shape for a GT...ive put almost a $1000 in the engine a couple months ago redoing all the gaskets and putting a new radiatior and a tranny flush...ive never had any problems with anything but an oil leak but i just like to keep up on what i got...i was just under the understanding that i would have to change my whole transmission when i get the top swap...why would i have to change the gears in it.....is that just for torque?
  8. #8 Re: comp g transmission
    Charles City, IA
    Get a built tranny from dave at triple edge performance /end thread.
    SMGPFC Two Nipple General
  9. #9 Re: comp g transmission
    you want a 98+ transmission. that is 98-03. they are all the same and they will all break the same unless you build then. i would suggets a non-hd transmission for the gearing and then swapping the hd diff into it. if you REALLY want to make power, get a built transmission from dave at TEP.
  10. #10 Re: comp g transmission
    grand rapids, mi
    so whats so different about the 97 tranny?
  11. #11 Re: comp g transmission
    Charles City, IA
    Vacuum controlled pos.
  12. #12 Re: comp g transmission
    exactly. i recommend you do some research so you know what we're talking about.
  13. #13 Re: comp g transmission
    grand rapids, mi
    k...thanks for the advice and i will do a lot more reading....this was very helpful
  14. #14 Re: comp g transmission
    SE Level Member teamfbody's Avatar
    New Orleans/The Woodlands,Tx
    i have a 05 comp g and i need a transmission because the one i have doesnt drive foward,its real funny because in reverse it drives really well LoL! i dont really care about the "Tap Shift" i just want to drive my car,will a regular 05-08 GTP trans work in my comp g?
    **fbodyNATION** GM DIE HARD FAN<br>ZERO TOLERANCE 4 BULLSH*T.....NO PATIENCE 4 HATRED
  15. #15 Re: comp g transmission
    Charles City, IA
    No, the valve body is different and the computer could not control it.
  16. #16 Re: comp g transmission
    Waukesha, WI
    kunzie made the getrag 284 tranny swap, or the 282 will work too if your interested in a 5speed swap
  17. #17 Re: comp g transmission
    SE Level Member kyrebel's Avatar
    Dec 2010
    Louisville, Kentucky, United States
    Quote Originally Posted by teamfbody View Post
    when you had a working tranny was the tap shift a convenience or just another thing that can break?
  18. #18 Re: comp g transmission
    Quote Originally Posted by kyrebel View Post
    i got it with the trans already bad,i really got the car for a great deal
  19. #19 Re: comp g transmission
    Ottawa ON, Canada
    could you add like a tap shift with one of those trannys from TEP? or can u only have a tap shift with the comp ones (newer models 05-08)
    _______________________
    2002 Acura Rsx Type S - K20A2
  1. 05 gtp comp g vs 08 gxp?
    By miller in forum Off Topic Discussion
    Last Post: 01-06-2009, 12:23 AM
  2. Why do most of you think the Comp G is better than the GXP
    By Panther427 in forum General Tech Discussion
    Last Post: 01-01-2009, 03:17 PM
  3. '05 Comp G
    By mikes_comp_g in forum Introductions/Noob Questions
    Last Post: 12-30-2008, 11:31 AM
  4. anybody with a comp g please help!
    By miller in forum General Tech Discussion
    Last Post: 08-03-2008, 11:44 AM
