Thread: 3800 performance shift kit
Results 1 to 9 of 9
  1. #1 3800 performance shift kit
    GTX Level Member nicksilvergt99's Avatar
    Reading, PA
    Thrasher 4T65E Shift Kit: 3800 Performance
    says it wont work on our transmissions...but then at the bottom under notes it says it will. wtf haha
    also...is it worth it? I pln on getting a mail order tune so would this even help?
    "This shocker crap is for high school kids, it's all about the double gauntlets, that's right, 2 fists forearm deep, someone make me a sticker. double gauntlets > shocker"
  2. #2 Re: 3800 performance shift kit
    PA
    Quote Originally Posted by nicksilvergt99 View Post
    Your 99 GT has a 4T65E tranny in it. That should fit into a couple categories:
    APPLICATIONS:
    - 1997- 2006 Grand Prix GTP
    - 1998-2006 Grand Prix GT, GT1, GT2
    - 1997-2004 Regal GS
    - 1998-2004 Regal LS
    - 1998-2005 Monte Carlo (3.8L)
    - 1998-2005 Impala (3.8L)
    - 1997-current cars with 4T65E transmission
    - 1997-current cars with 4T65E-HD transmission
    Not sure where it says it won't work for your car.
    Edit:
    But I must say that this same thing can be made for a whole lot less than $98. I think I did the equivalent shift kit for like $10. Spacers from Lowes and bought the springs from my GM dealer. Gasket I reused.
    2001 GSE
  3. #3 Re: 3800 performance shift kit
    Reading, PA
    down a bit is says wont work on 4T65E transmissions i think its a typo.
    but damn thats cheap lol, im not super inclined though. do you have a write up on how to do it? im still learning about transmissions and stuff
  4. #4 Re: 3800 performance shift kit
    CT
    Changing that stuff is really easy. When you drop the transmission pan you'll see the accumilator house (I hope thats what its called) which has like 3 metal tubes going into it. There are a few bolts holding this on. You just unbolt it and then pull the pistons and such out and drop in the spacers.
  5. #5 Re: 3800 performance shift kit
    PA
    Do you mean here:
    NOTES:
    - This kit will NOT work in a 4T60 transmission. The trans is very similar to the 4T65E, but not close enough.
    - Clutch life is improved because of the reduced shift time. Anytime you are between gears you are slipping the clutches until you reach the point where they lockup. This wears the clutches and generates heat. Less time on the shift = less clutch wear and heat buildup.
    - The kit will also work with the standard version of the 4T65E. (Supercharged cars get a HD version.)
    Notice that the first note says it will not work with a 4T60 transmission, and the last note says it will work with a 4T65 transmission. 4T60 =/= 4T65.
    As for a writeup, check out the thread at CGP:
    DIY Shift Kit
    And also the PDF they mention there:
    DIY Shift Kit & Filter/Fluid Change
    Edit: And just noticed that you are from Reading. If you ever get to Central PA, stop at my place and I can show you how to do it.
    2001 GSE
  6. #6 Re: 3800 performance shift kit
    Aug 2008
    KCMO
    marking this for later
  7. #7 Re: 3800 performance shift kit
    Reading, PA
    might be worth the trip
  8. #8 Re: 3800 performance shift kit
  9. #9 Re: 3800 performance shift kit
    Reading, PA
    so the tune pretty much does the shift kit?
  1. 3800 performance stage 3 package
    By schreurs1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-01-2013, 02:51 AM
  2. 3800 performance pcm
    By brodyman in forum PCM Tuning
    Last Post: 12-28-2009, 11:24 AM
  3. 3800 Performance Kits
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 08:17 AM
  4. 3800 Performance PCM
    By blueguy in forum General Tech Discussion
    Last Post: 08-17-2009, 12:34 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
