Ok well last night I drove to a nearby town and when I was on my way back all of a sudden my cruise stopped working, but this was as soon as I got home so i didn't think much of it. Well this morning I get in my car and when I put it in D it acts like it is taking off in a snow gear, then I also have no OD (60MPH - about 3K RPMS) This is all accompanied by hard shifts and PO753 (I think). I have the Pressure control Solenoid replaced maybe 1.5-2K miles ago and it worked perfectly for a while
Another problem that had started to occur was, well.. ill just explain it this way. It didn't happen all the time, but most time I would be cruising around 45-50 then try to give it more gas and the tranny would cluck and stay the RPM's would go nowhere, but if I let off the gas doing the same speed then pressed back down on it it would work fine. Could this problem be caused by a solenoid on its way out?
