Thread: Getting a shift kit
Results 1 to 11 of 11
  1. #1 Getting a shift kit
    GXP Level Member ryangtp89's Avatar
    Maine
    Im getting a shift kit from zzp, any experience or input on it ?
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: Getting a shift kit
    Oklahoma
    Moved your post to the tranny section.
  3. #3 Re: Getting a shift kit
    GTX Level Member MTXGTP's Avatar
    wamego,KS
    make sure you torque the accumulator down and get messy
    Justin Young, Kansas
    1999 silver GTP DHP pcm,3" Cattless hogan DP,Front PLOG,3.4 pulley, ported TB, ported LIM, ported supercharger housing.porting done by GBP
    coming soon: LS6 springs ,1.9rr
  4. #4 Re: Getting a shift kit
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    The hardlines should slip back into the accumliator easily. If you have to fight them, take it off and try to install again.
  5. #5 Re: Getting a shift kit
    The term shift kit is used too loosely. Pulling the pan and installing some shims in the accumulators should not be called a shift kit, because it doesn't fully correct for the major problems that exsist in the trans. Transgo actually makes a real shift kit for this car, but if you are looking for tire chirping shifts you are going to have to get creative because this trans isn't backed for much performance to my knowledge
  6. #6 Re: Getting a shift kit
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    In stock form these transmissions are fairly sloppy and things start breaking around the 300whp mark, but GM racing uses them in their 1200 HP sunfire race car and there are several of them running 9 and 10 second quarter mile runs by the big vendors out there. After a few parts are upgraded in these transmissions they will take a lot of power no problem. You are definately on the nose about the term Shift Kit, that is a registered name from Transgo and everyone copies the name, have for years and years but that is just how it is and for people not in the trans industry they dont know any better so anything that changes shift behavior is called a shift kit. I dont even bother pushing this because I would be kicking a dead horse and stirring a lot of pots lol. Shift Kit is just easy for everyone to relate to I guess and they know what its intended purpose is. While Transgo does have a kit for this trans its not one of their better kits compared to other products though it does help out and makes a great base for package of upgrades that nobody else offers, especially the accumulator spring setup.
  7. #7 Re: Getting a shift kit
    Yes!!!!!!!!!!! this is what i'm interested in tranny guy. I mean I love transgo and all, but their shift kit really doesn't do much as far as upgrading the shift quality to get those tire chirping shifts that some of their hd kits do. I'm really famialir with these trannies, but I've yet to find info on how to really got those crisp tire chirping shifts out of these. If you are willing i'd love to get info on where to get a shift kit that gives this trans the tire chirping shifts that some of us really want.
  8. #8 Re: Getting a shift kit
    Fort Wayne, IN
    I do internal work in addition to the Transgo kits to make the shift firmness/quickness match the cars power levels but unless you are rebuilding the trans and the whole thing is apart it doesnt help people looking for the quick easy upgrade. For selectable shift firmness and hard shifts, if you really want that, then the best shift kits out there are from Intense and if you can find an original Thrasher/Transgo kit. They include new accumulator springs and selectable spacers with firmness levels in the instructions. And of course the cheapest route is to go with the W-body store or ZZP kit which is nothing more than spacers that anyone can buy at a hardware store and they do not include any new firmer springs, but simply act as spacers to limit accumulator piston travel but wont give the full benifit of the better kits. Pcm tuning is another way to get harder shifts, you can make a stock trans bark the tires just by doing some tuning though I never recommend this as you really have to turn up the pressure to accomplish this.
  9. #9 Re: Getting a shift kit
    awww no disrespect I was just looking for the recalibration kit that would basically do what the other big box transgo shift kits do. What I mean is that I prefer to not mess with the computer tuning, because it is only capable of controlling the e.p.c., what I'm looking for is internal shift calibration not just blocking off the accumulators. I honestly have no ideas as of yet, but i'll tell you one thing turning in the e.p.c is not as sensitive as other vehicles.
  10. #10 Re: Getting a shift kit
    Fort Wayne, IN
    Im no fan of blocking the accumulators either nor do I prefer having to tune a car much to raise line pressure but every car is different and I like being able to tweak the shifts in the pcm. Transgo made the original Thrasher shift kit which was identical to what they offer now but had selective firmness levels, more spacers, and shims that go under the smaller springs on the acc pistons. That kit would make the tires bark on high settings. One nice thing about the pcm controlling shift firmness is that it will relearn part throttle to tame down the shifts more you drive it. After I build my transmissions sometimes the light and part throttle shifts are very harsh because of its mods but will learn quickly to this and make normally driving nice and have great WOT shifts. I never tried playin with adjusting the EPC on these transmissions and the solenoids that I have been using the last year arent adjustable like the OE delco ones because the adjustment screw is peened in so tight.
  11. #11 Re: Getting a shift kit
    I'm learning more and more everyday, and today I was having problems with a problem customer complaining that he wanted his shifts to snap his neck no matter how fast or how much throttle he was giving it. Basically all I did was say well every customer is different and i'll adjust your shift kit to the firmest settings, after doing so it wasn't as drastic of a difference as I was hoping for so I called transgo and talked to Glen in the tech department. Basically heres what he told me in a nut shell... If you are getting the tires to break traction upon the 1-2 shift , or chirp you are already pushing the limits and are getting into breaking parts stages, so if you are there and it doesn't please someone, then just block the accumulators completly and say good riddance I hope you blow your trans to shreds. I guess shift quality is measureable on so many differenty levels if you really want to get technical. As for me I'm now happy with the transgo shift kits, the way they are meant to be
  1. Adding Performance Shift [*]
    By GeddyLee in forum How To Write-Ups/Tech Tips
    Last Post: 08-11-2014, 06:44 PM
  2. Shift Kit[*]
    By Trannyman95 in forum How To Write-Ups/Tech Tips
    Last Post: 06-03-2012, 01:40 PM
  3. WOT Shift Points...RPM/MPH
    By japslpr in forum PCM Tuning
    Last Post: 02-04-2008, 07:12 PM
  4. Which shift kit would you recommend?
    By oldsman105 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2008, 02:09 PM
  5. why did they get rid of the performance shift ?
    Last Post: 01-17-2008, 02:18 PM
