02 Se model automatic.
the TCC needs changed i have a CEL for that, the speed sensor and the crank sensor.
i was driving it home from work the other day and it kept jumpin and jerkin which i already knew why.
but anyhow i pulled into the driveway and then it wouldnt go forward any further.
i put it in 1st gear and it moved it.
well 1st and 2nd gear the car will move. so will reverse. but when i put it in 3rd or drive it doesnt go nowhere.
now when i put it in park and pull it through the gears the transmission will engage but when i go from Neutral to Drive. the transmission wont even ingage. or 3rd for that matter. it acts like it is still in neutral.
what can this be causing this?
there is no burning or hot smell that comes from anywhere.
i havent checked the fluid level since it did this last night. im fixing to in a few
i already figured i would need a new transmission but if i can get around having to that would be great.
i got all the sensors that i need to fix the car, but with work i just dont have any time to do nothing and i dont have money to let a shop do it.
