Thread: disable lockup 1999 regal gs
Results 1 to 20 of 25
  1. #1 disable lockup 1999 regal gs
    Donating Users smokingjoe's Avatar
    cleveland ohio
    is there an easy way to disable lockup function of the torque converter?
    maybe somthing with brake switch.
  2. #2 Re: disable lockup 1999 regal gs
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    There are ways to do this but without a tuner you are going to throw trouble codes and some of them will cause the trans to go into limp mode and have max line pressure. Why would you want to dissable TCC?
  3. #3 Re: disable lockup 1999 regal gs
    Banned
    New Port Richey Florida
    To the orginaly poster. If you have no tuner there is a plug in the front of the trans near the top of the case on the side were the exhaust cross over is it should be a round plug plugging into the trans pull it and lock up is shut down and no codes will be tripped. Because tkere will be no power going to the tcc switch.
  4. #4 Re: disable lockup 1999 regal gs
    Banned
    To the orginaly poster. If you have no tuner there is a plug in the front of the trans near the top of the case on the side were the exhaust cross over is it should be a round plug plugging into the trans pull it and lock up is shut down and no codes will be tripped. Because tkere will be no power going to the tcc switch. thats the cheap way to do it if your in a fix...
  5. #5 Re: disable lockup 1999 regal gs
    Fort Wayne, IN
    What are you talking about????
    Above is the ONLY connector that goes inside a 4T65E and clearly if you disconnect this you lose everything, and it WILL throw codes, OBD2 systems throw codes for ANY transmission electrical problem. If the TCC switch in the transmission doesnt switch when the solenoid is commanded a code throws. If the solenoid isnt hooked up a voltage or short to ground code throws. When TCC slippage is over 250rpm for a certain time when commanded a code throws.
  6. #6 Re: disable lockup 1999 regal gs
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Quote Originally Posted by 19SE92 View Post
    what in the world are you talking about? if you unplug that round plug, the trans wont do jack! you need to watch what you are telling people, man
    look at the connector list in that... you are confused my friend!
    disable lockup 1999 regal gs Attached Images
  7. #7 Re: disable lockup 1999 regal gs
    cleveland ohio
    i have a shift kit and trans interceptor to increase line pressure, and when ever it goes in to lockup there is an annoying jarring type shudder, but i am very pleased with the rest of the shifts.
    i am not worried about gas mileage.
    thanks trannyman in advance
    Joe Gancos
  8. #8 Re: disable lockup 1999 regal gs
    SW Chicago Suburbs
    imho, that just sounds like trouble waiting to happen
  9. #9 Re: disable lockup 1999 regal gs
    cleveland ohio
    i have been running this set up for 4 years, i just dont like the lockup even when new.
  10. #10 Re: disable lockup 1999 regal gs
    Oklahoma
    I REALLY try to be patient with people, particularly in this kind of environment where you have the multitude of backgrounds, personalities and so forth. And I try to play nice. I even try to put myself in the other persons shoes hoping to see things from a perspective I may give little consideration to.
    But dude, Ive tried to look at it from different angles trying to figure out WHY in the world you would tell someone to disconnect the ONLY electrical plug to an ELECTRONICALLY controlled transmission. A transmission that DEPENDS on signals from the pcm to work properly as a complete system, not just TCC Lockup.
    I dont know exactly what thought process you used, but it was a run away train that derailed in a metropolitan area and I certainly would appreciate if you would give serious thought to what you are about to post with respect to such advice.
    I'll stop there because I am just about to boil over and I prefer to refrain from making you target practice.
  11. #11 Re: disable lockup 1999 regal gs
    PA
    Quote Originally Posted by smokingjoe View Post
    Joe Gancos
    This is auctually quite common from what I have heard. My tranny did it to me when I started changing stuff, increasing line pressure, shift kit, etc. But I solved it by changing the shift points, and lock up points in my trans. And it does not do it anymore.
    But I must caution you. Making your tranny not go into lockup can be very bad for your tranny. If you drive like this for any amount of time, your tranny temps will increase A LOT and it will not shift right. On top of this, the increased heat generated can cause the fluid to degrade at an increased rate and cause permanent damage to your transmission. This can happen just if you are driving it easy and not even beating on it. Just think what would happen if you start to drive aggressively. For these reasons, this kind of change is not recommended by anyone.
    2001 GSE
  12. #12 Re: disable lockup 1999 regal gs
    Fort Wayne, IN
    What Zef said is 100% correct. If it is all in town driving then its not really going to make much of a difference, but highway driving is not going to be that good on the trans or fluid as locking up the converter gets rid of the converter slippage which creates heat, not to mention the few mpg you will lose. Out of curiousity have you tried unplugging the Intercepter yet???? I would try that. I have one here that the output transistor that controls the lockup solenoid was burned up and I can see that causing a lot of grief on the circuit and possibly causing what you have going on. Also there is a delay control for TCC in that box, have you tried adjusting that?
  13. #13 Re: disable lockup 1999 regal gs
    GT Level Member shaferz's Avatar
    Forrest IL
    lol, are you serious?
    99 GTP = 12.936 @ 112.12 2.16 60'
    06 TBSS = STOCK
    07 GXP = STOCK - ordering SSC's
  14. #14 Re: disable lockup 1999 regal gs
    PA
    FWIW, I kinda think I know where he is getting this info from. On my 440-T4, which was NOT electrically controlled, but rather vacuum controlled, I could pull the wiring plug on the front of the trans and disable lockup without any problems. So if his name is correct, he may be able to do the same on his 1992. But there is no way you can do this on a 97+ GP.
    2001 GSE
  15. #15 Re: disable lockup 1999 regal gs
    SW Chicago Suburbs
    Quote Originally Posted by Zef_66 View Post
    that's what we're getting at. the topic clearly states the op has a 99 MY. 99 MY GS=L67=4T65E-HD --- these are facts. and immediately he says unplug the connector and it will do what you want. obviously he doesnt really have any clue about these transmissions. It'd be one thing if he asks if it has a separate electrical plug, or asks specifically which trans it is...
    i'm sure he knows stuff about the gen 1 cars. that's fine. but to assume that one knows about all transmissions in these late model W body cars too... sorry, charlie. do your homework.
  16. #16 Re: disable lockup 1999 regal gs
    PA
    Quote Originally Posted by Toasty View Post
    You and I understand this. But it was never stated. So for the sake of someone coming in here and seeing up tearing apart this guy, I was giving the reason. For others benefit, not your toasty.
    2001 GSE
  17. #17 Re: disable lockup 1999 regal gs
    SW Chicago Suburbs
    eh, i suppose so. i try to be as understanding as i can--- some people just seem to come off as know-it-all types. perhaps not meaning to be, but it can seem that way sometimes.
  18. #18 Re: disable lockup 1999 regal gs
    cleveland ohio
    Quote Originally Posted by Trannyman95 View Post
    the interceptor i have only has an external adjustment for line pressure, i heard the older ones had it for both line pressure and tcc, unless under the box cover the pot for adjustment is still there.
  19. #19 Re: disable lockup 1999 regal gs
    Oklahoma
    they are calling it all sorts of things and hiding it all sorts of places now days aren't they
    Sorry, didnt mean to hijack your thread but I couldnt resist.
  20. #20 Re: disable lockup 1999 regal gs
    Virginia
    I know that this is a very old thread, but perhaps someone in the know will breeze back thru anyway. I am currently looking for a way to - temporarily - disable TCC lock up on a 2000 Olds Silhouette (4T65E).
    Mine is basically dropping in and out. At higher speeds (70 mph hi-way) its mostly unnoticeable unless you watch the tach. At 45-60 or so it gives a pretty bad stammer.
    I've had it to a shop but just my luck the real trans tech wasn't there the day I brought it in. Of course, no one mentioned this minor fact to me even though I was bringing it for a trans scan! I can't stand this logic that scanners can just handle it independently of expertise. I learned nothing on my first trip.
    Anyway, I am going to get it back to a shop but its not easy for me to have a day when I can just leave it all day (every shop requires it) - its major family logistics & time engineering. I'm looking at about a week from now.
    In the meantime the van is fine, including all gear/shifts other than the lock up problem, and it needs to be used for normal family stuff. There's the wife's 30 mi round trip to work (rural hi-way and suburb/city style roads) and the running around of kids to here and there.
    I just cringe thinking about this happening and the additional damage. It might turn out to be a catastrophic problem - or I might turn it into one just by driving it.
    Anyway, I thought that pulling the TCC switch wire from the brake switch (purple from PCM) would do it since it would break the circuit continuity - which is what the brake switch does - but I was apparently wrong about that since it didn't seem to make a bit of difference.
    If whatever can be done triggers limp mode, then I'll just undo it.
    It makes no sense to me that there is no easy way to just turn the dumb thing off. This thing was equipped with air shocks and trailer wiring for pete's sake. How about a nice little O/D off button?
    If anyone comes through and can help I'd be much obliged.
  1. another regal owner
    By monte0 in forum Buick Regal
    Last Post: 12-22-2009, 09:59 AM
  2. Who let that Regal guy in??
    By Fish in forum Off Topic Discussion
    Last Post: 09-03-2008, 01:03 PM
  3. Regal from PA
    By RLewis15 in forum Introductions/Noob Questions
    Last Post: 01-21-2008, 11:44 PM
  4. I own a regal
    By GS-SC in forum Buick Regal
    Last Post: 12-19-2007, 02:28 PM
