Thread: 98 GTP leaking tranny fluid
Results 1 to 3 of 3
  1. #1 98 GTP leaking tranny fluid
    SE Level Member millfire517's Avatar
    Jan 2009
    Indiana
    Ok my car is leaving about a 12" or a little bigger wet spot on the driveway under the center of the tranny overnight. Any suggestions on what it might be, im thinking of "HOPEFULLY" tranny pan gasket, but knowing my luck it will be something a little more complex. it just started this a few weeks ago
    1998 Pontiac Grand Prix GTP 4dr red. all stock with 185,xxx miles.
  2. #2 Re: 98 GTP leaking tranny fluid
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    It could be the pan gasket but they arent very common to leak that bad unless the stock molded pan gasket was replaced at some point with a cheap cork or thin black composite rubber gasket and those never seal on these pans because they werent stamped to work well with that type of gasket. A more common area of leak is an axle seal at either end OR the differential housing is damaged and has a crack or hole in it because the differential is failing. The only way to know for sure is to get under the car and clean off everything good with a can of spray parts cleaner or brake cleaner to get everything dry and then let the car sit. It will also help to lay a clean piece of card board under the car to know what area to start hunting
  3. #3 Re: 98 GTP leaking tranny fluid
    Jan 2009
    Indiana
    well i took it to my buddy, and it looked like the pan gasket, after we pulled the pan he found the gasket was dry rotted and had a few cracks in it. so we replaced filter and gasket, and have had no noticeable leaks as of yet
  1. Leaking tranny fluid
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 07:00 AM
  2. Help!! Tranny leaking fluid
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 06:48 AM
  3. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  4. tranny leaking.....
    By badgtp2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2008, 03:38 PM
  5. Fluid Leaking out of Axle Seal Still
    By Metallistar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 04:39 PM
