Ok, so I replaced the Axle Seal on the drivers side of the tranny and I thought all was ok, but now fluid is seeping out of the new seal. What else could be wrong?
Well I hate to be the one to ask an obvious and probably silly question, but are you sure you used the correct seal? And are you sure the leak is coming from the seal?
also you have to be ALL the dirt was clear of it.
It could be that the fluid is leaking out between the seal and the axle shaft. The axle shaft may be undersized, worn down, or something. You might have to replace the axle...
I would also look very close at the area around where the seal goes. There is an oring in the side cover that seals up against the channel plate, which is where the seal goes, and if the oring is going bad or wasnt installed properly fluid can slowly seep from it. The only way to replace that is by removing the side cover. I would clean it all off good with parts cleaner and make sure it is dry and look carefully where the leak is coming from, maybe snap a pic and post it up where the wet area is.
Ok, I took a pic of the leak, let me know if you need a better angle or something, kind of hard with the tie rod and sway bar in the way.
Edit: That was after I cleaned the area and let dry, then started the car and ran it through the gears for about 2 mins.
That definately looks like it is coming from the axle seal from that angle. Is it dry above the seal in that area? Your inner CV may have a grove worn into it or corrosion/rust causing it to leak. I hate to say it but you are going to have to take it back apart to find out. There is a roller bearing that the CV rides on that is just behind the seal. I would take a peak at that to make sure it looks in tact and look carefully at the CV shaft. You dont have any odd vibrations do you?
Yeah, I'm going to do that next, I have a spare drive cup I can throw in there and see if it still leaks. I also have a spare axle seal, so if thats the problem I can rip that one out and replace it again.
You wont see the spring, it is on the back side of the seal and is held by the lip molded in the back side of the seal. If you look at a new on you will see what I am talking about. It is called a worm spring and it keeps tension on the seal against the shaft. It is possible to pop the spring out while you are pounding in the new seal.
Ok, just wanted to say, that Trannyman was right, the little spring in the seal was ever so slightly poped out so it wasnt sealing on the inner surface and causing it to leak. Put another seal in there and now every thing is leak free.
Thanks for all your help Trannyman!
Thats good, if I may recommend, take a moment to click on his reputation icon and click 'I approve' and leave a brief comment. Something short stating how he helped you out.
