Thread: Pressure control solenoid, anyone got a writeup on changing it?
Results 1 to 20 of 22
  1. #1 Pressure control solenoid, anyone got a writeup on changing it?
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    I have a 99GTP with 70k on it and it has been slow to shifting lately and is getting worse. I've been reading up around here on similar conditions and it seems that the culprit is probably the PCS. I have some time off this next week and I want to go ahead and replace it.
    I haven't bought a Haynes manual in the hopes that I never needed it, but I have no clue how to go about changing this part. Anyone have a writeup on changing it?
    I also want to know if there are any suggestion on what i should do while im inside the damm thing. should i go and install a shift kit while at it to reduce this from happening again?
    I've been pretty fammilar with my manual trans in the camaro, but i've never touched this car with a wrench yet so any information would be helpful.
    Engineering the impossible.
  2. #2 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Broken Arrow, OK
    Anyone? Noone?
  3. #3 Re: Pressure control solenoid, anyone got a writeup on changing it?
    montana
    ya does anyone have a write up on changing the Pressure Control Solenoid? Im in the process of replacing it some extra info would be greatly appreciated
  4. #4 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Broken Arrow, OK
    i just wrote up a small writeup in another thread. search for epc solenoid under my name
  5. #5 Re: Pressure control solenoid, anyone got a writeup on changing it?
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    It's under epc help thread by me. I think I may get mine done by a shop though since it seems like a lousy job to do on the ground.
  6. #6 Re: Pressure control solenoid, anyone got a writeup on changing it?
    Jul 2008
    Germantown, Maryland
    its takes some time to do... I replaced my epc a few months ago... I don't have a write up or anything because my brother is the one that changed it. I know the epc is on the side though and of course the trans needed to be dropped as well as one of the axles. Labor costs of this job are through the roof. It wasn't that hard to do, just takes time. If you do it yourself you'll save a good $800+.
  7. #7 Re: Pressure control solenoid, anyone got a writeup on changing it?
    montana
    ya im in the process of doing it right now, except i dont have a socket big enough to remove the spindle to get the axle off. So i went to napa and they said they had no idea what size it but they said a 32mm would fit, that costs $28.95 so i bought it and it didn't even fit it was too small. Does anyone know the correct size to remove the spindle to get the axle off?
  8. #8 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Ontario
    Quote Originally Posted by Quicklynx View Post
    Damn, I was quoted arounf $400 from mr transmission. I thought $400 is bad, $800 would be crazy!
  9. #9 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Broken Arrow, OK
    the socket is a 35mm. i bought mine at o relies for 9.99.
  10. #10 Re: Pressure control solenoid, anyone got a writeup on changing it?
    Jul 2008
    Montgomery County, Maryland can run very high on the money side....
  11. #11 Re: Pressure control solenoid, anyone got a writeup on changing it?
    Barksdale AFB, LA
    Dealer quoted me $400 in labor when I asked out of curiosity. That was with me bringing them the part.
    2009 Subaru Impreza WRX STI
  12. #12 Re: Pressure control solenoid, anyone got a writeup on changing it?
    Jul 2008
    $400 is much more reasonable. I mean it does take awhile to do. It's not a quick fix.
  13. #13 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Broken Arrow, OK
    Thats about what i got on a quote, but I couldn't justify paying someone to do the work on something so easy.
    Then I actually did the part swap, and I think I might pay a guy if it ever happens again.
  14. #14 Re: Pressure control solenoid, anyone got a writeup on changing it?
    montana
    Quote Originally Posted by Merlin View Post
    really? my o reiles dosent even carry those large of sockets
    but i got the right size one of my neighbors actually had the right size and ket me borrow it
  15. #15 Re: Pressure control solenoid, anyone got a writeup on changing it?
    Jul 2008
    Yea, seems like a quick fix but def wasn't
  16. #16 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Broken Arrow, OK
    Its in the tool section, but not with all of the sockets. My socket was an actual orelleys tool though.
  17. #17 Re: Pressure control solenoid, anyone got a writeup on changing it?
    May 2008
    Ontario
    Haha, I feel the same way but when I look into how much work it is I think I will be getting the shop to do mine.
  18. #18 Re: Pressure control solenoid, anyone got a writeup on changing it?
    montana
    when removing the epc & shift solenoids do you have to remove the valve body to get them out? or do they pull or slide out without removing the valve body?
  19. #19 Re: Pressure control solenoid, anyone got a writeup on changing it?
    GTP Level Member Scimmia's Avatar
    QCA, IA
    They're held in with a clip, just remove the clip and they slide right out.
    2001 Buick Regal LS - Almost Stock
  20. #20 Re: Pressure control solenoid, anyone got a writeup on changing it?
    Jul 2008
    yea... no need to remove valve body
  1. Key Removal Solenoid
    By thermanlee in forum General Tech Discussion
    Last Post: 08-12-2012, 01:40 PM
  2. bbv solenoid
    Last Post: 03-11-2009, 01:42 PM
  3. Big 3 writeup?
    By 2kblackgtp in forum Audio, Security & Visual Electronics
    Last Post: 01-11-2009, 05:01 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. Need a writeup
    By sra_chipmunk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-08-2008, 09:04 PM
