Thread: Ssei tranny
Results 1 to 2 of 2
  1. #1 Ssei tranny
    SE Level Member 98GTPON22s's Avatar
    Jan 2009
    Lithonia GA
    will the transmission out of a 99 ssei bonneville work on a 00 gtp
    Dont Think Cause Its On 22s I Wont Race You
  2. #2 Re: Ssei tranny
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    It should work just fine. The case has a bit extra meet on the back side for the bonny trans mount but otherwise will fit just fine and will also have the correct gear ratio. The cooler lines will be different as the 00 uses quick connect fittings and the 99 will have threaded lines but you may be able to use the 00 fittings in the 99 case, it is a hit and miss year to do that with so if it wont work you will have to use different cooler lines.
  1. 96 bonne SSEi
    By tan96ssei in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:35 AM
  2. 01 tranny in a 97
    By merked in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2008, 03:55 PM
  3. 9C1 Tranny Help
    By cobraz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-22-2008, 08:51 PM
  4. Tranny???
    By Darkcelle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2008, 10:36 AM
  5. New Tranny plus ??????'s
    By Sherif41119 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-26-2008, 03:24 PM
