Thread: Bouncing speedometer
Results 1 to 6 of 6
  1. #1 Bouncing speedometer
    Wichita
    Like the headline says my speedometer started bouncing at low speeds yesterday. I went ahead and replaced the speed sensor. That didn't fix it. What I'll probably end up doing is dropping the car off at one of the local tranny shops and have them test drive/scan the car. & See what they find. I'm assuming this is a transmission issue. But l, before I do that does anyone have any thoughts on this? Like maybe the shift solenoid?
  2. #2 Re: Bouncing speedometer
    Mar 2014
    Tucson
    I would check the vehicle speed with some sort of OBD2 device. That would narrow down the source of the problem. Is it a problem with the signal the cluster is receiving, or a problem in the cluster itself. Thinking maybe you got a stepper motor going bad.
  3. #3 Re: Bouncing speedometer
    Wichita
    The only other things that happen are the radio sorta cuts out/volume got crackly and wierd while the speedo was bouncing. That and shifting from reverse into first and second the car was slow to shift, like, twice.
  4. #4 Re: Bouncing speedometer
    Donating Users
    Aug 2021
    Rochester, NY
    Voltage problem? But if it was that low, I would guess you would notice trying to start the car.
  5. #5 Re: Bouncing speedometer
    Wichita
    I decided to check the harness for damage. We looked down near the vehicle speed sensor & under the hood. Sure enough there were a couple of frayed wires going to the TCM. No doubt damaged by the air filter rubbing against it. Patched it up, went for a drive, and so far no more bouncing speedometer.
    I'll have to keep a close eye on it for the next few days. If it happens again it's going to the tranny shop.
  6. #6 Re: Bouncing speedometer
    Wichita
    Ah oh, my speedometer & HUD are no longer in sync. Speedometer reads 40mph while the HUD reads 41/42.
  1. bouncing suspension
    By buckslayer in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:09 AM
  2. 99 GTP, RPM's bouncing at 11-1600
    By AKGTP19 in forum General Tech Discussion
    Last Post: 03-15-2013, 06:49 AM
  3. rpms bouncing while driving between 2nd and 3rd
    By RyanL in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2012, 02:57 AM
  4. Exhaust is bouncing...HELP!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-12-2010, 02:55 PM
  5. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
