Thread: Help me plan my rebuild/strengthening
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: Help me plan my rebuild/strengthening
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    So after talking to folks on here, and the guy from TEP. I think im going to back off on my trans plans.
    I already bought the input shaft, and i do plan to install that. My trans is also shifting lazily between 1-2 and 3-2 . So i think im going to get new shift solenoids as well as a shift kit.
    The full rebuild isnt something Im going to do. If i grenade the trans i loose all of that work. at tax time, ill probably get the stage 2 build kit from TEP and do a proper build with a 1 inch chain etc.
    My question is, what is invovled in installing the input shaft. what seals and stuff will i need?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #22 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    TEP has a 1 inch single chain set. so instead of all the other stuff i was going to get, im going for that.
  3. #23 Re: Help me plan my rebuild/strengthening
    Mar 2014
    Tucson
    Quote Originally Posted by 04lss View Post
    He does? Got a link?
  4. #24 Re: Help me plan my rebuild/strengthening
    May 2008
    Schuyler, NE
    I just want to point out that it doesn't make any sense to use a 4340 input with a 1" chain.
  5. #25 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    Why not? The 4340 is good (according to zzp) up to 450hp Thats what TEP and Gearstar put the limit of the 1 inch chain at.
  6. #26 Re: Help me plan my rebuild/strengthening
    May 2008
    Schuyler, NE
    You are talking about something other than the gmr 1" chain then?
  7. #27 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    4T65E 7/8" Single Chain Conversion Set This is what i think im talking about.
  8. #28 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    I guess i figured they were the same, but apparently not. though i did find this MMS 1" High Performance Gear Set for 4t65e Transmissions - Milzy Motorsports
  9. #29 Re: Help me plan my rebuild/strengthening
    May 2008
    Schuyler, NE
    Both of those suck. You are way better off with gxp chains.
  10. #30 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    Whats your reasoning on that? TEP reccomended the 7/8ths chain over the GXP gemenai set .
  11. #31 Re: Help me plan my rebuild/strengthening
    May 2008
    Schuyler, NE
    I've seen 7/8 chains stretch with 300whp. They are little if any stronger than stock.
    Gxp chains are holding 600whp on a few cars. 500whp is about their comfortable limit though.
  12. #32 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    That doesnt seem to match what TEP ZZP and a few other sources have said.
    On a similar note, GM used the GXP chain for all stock chain replacements after a certain year, so if you buy a stock gemenai chain set its most likely the GXP chain.
  13. #33 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    I should note im not trying to argue, i just want to make sure i buy the right parts.
  14. #34 Re: Help me plan my rebuild/strengthening
    May 2008
    Schuyler, NE
    They all make a good amount of money selling 7/8" chains too. They never should have been pushed as an upgrade because they aren't. I think Dave may have changed his opinion on them as of late too.
  15. #35 Re: Help me plan my rebuild/strengthening
    Sep 2014
    Richmond Virginia
    Dave told me as recently as last week that the GXP chain wont hold.
  16. #36 Re: Help me plan my rebuild/strengthening
    May 2008
    Schuyler, NE
    Well, he might be right there. But they will hold a hell of a lot better than the 7/8".
  17. #37 Re: Help me plan my rebuild/strengthening
    SE Level Member Jonnyboy's Avatar
    Jul 2016
    Los Angeles
    Extremely interesting info right here. I'm already looking for the parts I will need for a full trans rebuild and wanted the best TEP had to offer so I contacted them but they say for anything above 375whp they would need this 1" chain that is hard to come by so they can't help. But I am happy to hear GTPpower say that the GXP chains are a better alternative from actual experiences. I'm personally hoping to reach 450-500whp with the stattama kit.
    Sent from my GM1915 using Tapatalk
  1. ok here's my plan
    By weissmertz in forum General Tech Discussion
    Last Post: 08-22-2015, 11:25 AM
  2. Here is my plan. what you think?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 05-28-2013, 01:33 AM
  3. Strengthening Transmission AKA Fix it before it breaks
    By daryl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2012, 08:00 AM
  4. New plan
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-08-2010, 03:31 PM
  5. GM's plan for the bail out
    By Sabrewings in forum Off Topic Discussion
    Last Post: 12-05-2008, 05:06 AM
