Thread: Bizarre Symptoms
Results 1 to 6 of 6
  1. #1 Bizarre Symptoms
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    My transmission has been sporadically staying in second when stopped, then thunking into first when I touch the gas. This happened with my Monte, when I found out I had a small leak. Fill er up, problem went away. I have no leak on this transmission, and the fluid is bright red and at the proper level.
    It also acted even more bizarrely on Monday. Twice it felt like it got stuck between two gears (probably second and third.) I freaked out so badly I didn't think of checking the temperature, and it hasn't happened again since. I almost want to believe it was a couple of rough patches of road, which is what it felt like. I do have a cooler I haven't installed yet. Is there anything else I should be looking at?
  2. #2 Re: Bizarre Symptoms
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Might be a common issue with the internals.
    No Forward Cold
    The most common cause of this problem is a worn out inner surface of the Input clutch piston. Once the inner sealing area wears it can prevent the inner lip seal for the piston from sealing properly. You may find that revving the engine up will finally get the car to move and it will BANG into gear.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Bizarre Symptoms
    Jul 2016
    Brevard County, FL
    Of course, the transmission ISN'T cold when this happens....
  4. #4 Re: Bizarre Symptoms
    Dec 2013
    Enfield
    You could try a product call Sea Foam Trans Tune, helps with sticking valves. I have used it in the past with good results. Wont hurt anything and its inexpensive. Install the transmission cooler right away, any of these cars should have had these factory installed hot running transmission is such a common problem.
  5. #5 Re: Bizarre Symptoms
    Buffalo NY
    I've also used Lucas transmission product and it worked really well with the rev-bang issue.
  6. #6 Re: Bizarre Symptoms
    Jul 2016
    Brevard County, FL
    The SeaFoam Trans Tune seems to have worked. Thanks a lot!
  1. Bizarre Electrical Issue
    By Hurricane87 in forum General Tech Discussion
    Last Post: 12-13-2019, 04:52 PM
  2. Bizarre situation with my '04 Grand Prix.
    By pigalow in forum General Grand Prix Discussion
    Last Post: 10-14-2015, 11:01 AM
  3. PS Pump Symptoms?
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 03-23-2015, 05:04 PM
  4. Bizarre issue with key fob (Tried ALL obvious fixes)
    By komrad36 in forum General Tech Discussion
    Last Post: 08-08-2013, 10:34 PM
  5. Low Oil Pressure but no symptoms?
    By EJOUIE in forum General Tech Discussion
    Last Post: 06-09-2011, 09:10 PM
