Thread: 245 Converter
Results 1 to 3 of 3
  1. #1 245 Converter
    Pittsburgh
    Anyone know the difference between the #4RDB & #5RDB? Is One for the 2004 and one for the 2005 specific?
    This is for the GM42CW , GM # 24224256.
    Did GM make a dual pattern flexplate?
    What do you recommend withe the 245, the NA flex or the dual pattern one.
    Any recomendations on a reman TC like Pro-King, DACCO ect.
  2. #2 Re: 245 Converter
    May 2008
    Schuyler, NE
    They did make a dual pattern flexplate in the later years. 04ish and newer.
    I would run the dual pattern.
  3. #3 Re: 245 Converter
    SE Level Member AndrewGXP's Avatar
    Jan 2015
    F-town
    Can confirm dual-pattern flexplate on 06 GXP, installed a Triple Edge HPS1 into girlfriend's gxp last November.
    For Torque converter give TEP a call or Precision of New Hampton, who provides the converters for triple edge performance.
    Automotive Torque Converters by Transmission
    10.750in Diameter is 273mm says google. If you can fit that and afford it, Id say its your best bet.
    Just looked over their site, precision does have a 10in( 254mm ) for the 4t65 also.
    06 GXP: Triple Edge Performance HPS1 Transmission w/ Precision Torque Converter
    Spectre Re-usable air filter
    Amsoil OE 5w30
    PowerStop Z23 Brakes
  1. 2.8 GP cat converter
    By Dmar73 in forum Engine
    Last Post: 06-29-2013, 05:06 PM
  2. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  3. converter?
    By timmysgtp in forum General Tech Discussion
    Last Post: 09-18-2010, 09:39 AM
  4. Converter I.D.
    By charlie31603 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2010, 03:17 PM
  5. 04 cat converter.
    By rcweldon988 in forum 04+ Specifics
    Last Post: 02-18-2009, 08:21 AM
