Thread: 4t65e rebuild 98 gp gt
Results 1 to 9 of 9
  1. #1 4t65e rebuild 98 gp gt
    Sep 2013
    Arizona
    So I just had my trans take its final drive today known for about a month it was going out. I pretty much decided I’m going to attempt an in vehicle rebuild since I don’t have a lift or a good enough jack to get my car off the ground to completely drop the subframe out. I watched the videos on YouTube of the guy who did an in car rebuild on an 03 impala and it seems simple enough. The problem im running into is what kit of parts I would need to buy for an in car rebuild? I know it’s not the ideal method to rebuild it but it’s what will work best for me for my set of circumstances.
  2. #2 Re: 4t65e rebuild 98 gp gt
    Mar 2014
    Tucson
    You're probably going to want a "Master Kit" That will include pretty much everything perishable minus the bushings and washers. Be sure that the kit you get includes the molded pistons and bands. Don't throw away the side cover gasket. It's reusable and I don't think it's included in any kit. If you still have the factory molded pan gasket, keep that too. It's better than cork or flimsy rubber.
    I see you're in Arizona. It's cool right now so you can probably use vaseline to hold/stick things together, but once it warms up you're going to have to step up to some high tack trans gel.
  3. #3 Re: 4t65e rebuild 98 gp gt
    Sep 2013
    Arizona
    I figured I would use assembly lube to stick things together but yes it’s nice out here in az right now to do the work. I was looks on rock auto for a kit so I’ll see if I see a “master kit” listed there
  4. #4 Re: 4t65e rebuild 98 gp gt
    Mar 2014
    Tucson
    I'm mistaken. To get it all in one box you need a Deluxe kit.
  5. Thanks mjsmith08 thanked for this post
  6. #5 Re: 4t65e rebuild 98 gp gt
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    This is the best manual I've ever found. You can watch it and pause it along the way and it holds your hand for you. Best money I ever spent on Ebay. STOCK DVD VIDEO TRANSMISSION REBUILD OVERHAUL MANUAL 4T65E-HD 4T65E 4T65-E TRANS | eBay
    In addition to the rebuilt kit, wouldn't be a bad idea for a shift kit and make sure to check the chain. The video steps you through all checks. You will need some specialized tools. I got away with a basic ebay clutch spring compressor with a few wood clamps for when it was too short. Please don't reuse your torque converter as tempting as it looks. Use dex VI when re-filling, and other than that, the video goes over all the rest!
    If you have specific questions. Between Bill, Brandon and I, we've probably done over 100 of these, so feel free to ask! Good luck!
  7. Thanks mjsmith08 thanked for this post
  8. #6 Re: 4t65e rebuild 98 gp gt
    Sep 2013
    Arizona
    I appreciate all your help I’ll check out the dvd that’s for sure
  9. #7 Re: 4t65e rebuild 98 gp gt
    Mar 2014
    Tucson
    x2 on the shift kit. Superior also makes some nice valve body goodies. All depends on how far down the rabbit hole you want to go.
    I forgot to mention a hardened 4th clutch hub. Yours being a '98, it probably still has the soft spline version.
    That DVD is pretty good. It shows you some different ways to do things if you don't have the special tools. I think it's also worth acquiring the ATSG manual. Those two together paint a really clear picture.
    Click the link in my sig for a walkthrough (not tutorial or how to) of a high performance 4t65e build.
  10. #8 Re: 4t65e rebuild 98 gp gt
    Sep 2013
    Arizona
    So I started watching the video after it got here on Tuesday and Ive decided I will just fully remove the trans from the sub-frame and engine to do the rebuild the correct way.
    I found this kit on rock auto and seems like it should be fine. Any opinions whether this is good or not? I have had pretty good luck with them in the past doing engine rebuilds.
    More Information for PA CARGO MRK8400U
  11. #9 Re: 4t65e rebuild 98 gp gt
    Mar 2014
    Tucson
    Raybestos steels, Borg Warner frictions and Trans-Tec seals. It's good stuff.
  1. 4T65E rebuild DVD!!
    By chrisb in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-05-2017, 01:54 PM
  2. 4T65E rebuild questions
    By 2000S80T6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-15-2014, 08:49 AM
  3. 97 4T65E-HD rebuild and questions
    By Nchristopherson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2014, 01:42 PM
  4. 4t65e HD OK after GM rebuild?
    By payne335 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-16-2013, 03:43 PM
  5. 4t65e rebuild...
    By MontyJ in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2012, 02:52 AM
