Thread: Snapped Input Shaft
Results 1 to 18 of 18
  1. #1 Snapped Input Shaft
    SE Level Member BrokenRhythm's Avatar
    Nov 2008
    north plainfield, NJ
    I was taking a ride the other day and decided to punch the car a little bit in performance mode. next thing i know i hear a "boom!' and lost all gears.
    Not the most fun but i guess i found another weak point in the trans. Just ordered the upgraded shaft from zzp. (and a dp and a whisper resonator) Ill take pics of the carnage when i go to the shop.
    just figured i would share another failing 4T65E-HD story for you all.
    pics soon!
    97 GTP, Thrasher intake, SLP cat-back exhaust, slp headers, whisper resonator, 3.4 pulley, ssc springs/agx, built trans, 3.29's,ati stall, DHP 1.0, AL 104's, HID's, PRJ wires, 40th interior and hood, 12" brakes, and too much more to list here
  2. #2 Re: Snapped Input Shaft
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Sucks!
    But been there done that. I have also striped all the splines on a Intense TQ Converter
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  3. #3 Re: Snapped Input Shaft
    TDCRacing
    Guest
    Sorry to hear that. Good luck with the upgrade.
  4. #4 Re: Snapped Input Shaft
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Snapped a turbine shaft with a 3.4" pulley? Wow, that sux, sorry to hear it.
    What does built trans in your sig mean if you had a stock input shaft?
    2001 Buick Regal LS - Almost Stock
  5. #5 Re: Snapped Input Shaft
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    You may also have a broken drive chain which causes a lot of carnage when it goes. Typically the input shaft will only break on a hard launch or during a very hard 1-2 shift, while the chains will give way pretty much any time you are WOT and typically at higher rpms.
  6. #6 Re: Snapped Input Shaft
    Barksdale AFB, LA
    First reading the post and seeing his mods, I was wondering if he was sure it was the input shaft. I'd be more inclined to believe it was the chains, since they're a wear item while the shaft is not.
    2009 Subaru Impreza WRX STI
  7. #7 Re: Snapped Input Shaft
    Nov 2008
    unfortunately the input shaft was one thing i just couldnt afford when i rebuilt the trans.. gotta love how things catch up to you in the end. went to the shop yesterday that previously built my trans. and yes, the input shaft snapped right in half.
    this is what was in the trans before:
    TSP-651 INTENSE™ Street/Strip Performance Shift Pak
    4CS-289 Heavy Duty Fourth Clutch Shaft 1
    PSK-65E 4T65E/-HD Pawl-Style Input and 3rd Sprag Kit
    CKO-100 Overdrive Clutch Kit
    CK2-100 Improved 2nd Clutch Kit
    GMH-PCS 1997 - 2002 Pressure Control Solenoid
    GMH-TCCS Torque Converter Clutch Solenoid
    GMH-SHS Shift Solenoid
    GMH-TFPS Transaxle Fluid Pressure Manifold Switch
    BVK-831 Improved Boost Valve and Sleeve Kit
    TNST-TBC Coast Band for the 4T65E Transaxle
    TNST-TBF Forward Band for the 4T65E Transaxle
    TNST-TBR Reverse Band for the 4T65E Transaxle
    And the upgraded 3rd gear clutch.
    im just gonna do a single chain setup now too while im at it.
    does anyone else know of any weak links that i should be cautious of?
    im not exactly putting down much hp, but it would be nice to know that if i started to go into one of my crazy modifying binges that it would hold up
  8. #8 Re: Snapped Input Shaft
    Nov 2008
    oh yeah, plus a torque converter and an external trans cooler were in the rebuild 4k ago
  9. #9 Re: Snapped Input Shaft
    TDCRacing
    Guest
    Don't get an 11/16 th's chain. Get a 7/8's. The 11/16 th's are garbage.
  10. #10 Re: Snapped Input Shaft
    Nov 2008
    how hard is it to replace the chain by myself? im not a trans guy, im more of engine/whatever guy. just curious if it is possible to do while the trans in in the car
  11. #11 Re: Snapped Input Shaft
    TDCRacing
    Guest
    I'm doing one right now. Out of the car. And I must say I would never attempt it in the car. But that's just me. It's pretty straight foward. It was mainly me being scared because I have never been in an automatic before.
  12. #12 Re: Snapped Input Shaft
    Nov 2008
    you think its worth doing the gear upgrade to the 3.29's?
  13. #13 Re: Snapped Input Shaft
    TDCRacing
    Guest
    Don't fear the gear. Go 3.69's. I wish I did although for most people 3.29's are MORE than enough. ESPECIALLY if they do a lot of highway driving.
  14. #14 Re: Snapped Input Shaft
    Donating Users Tengis's Avatar
    Houston
    3.69s are not fun (besides breaking loose from higher MPH) and I would not recommend them on a daily driver usually. Besides the fact that it kills gas milage... it makes 1st gear completely useless (especially with a turbo) and 2nd to 1st downshifts are even worse. Of course, with slicks thats all a different story.
    Also, third gear tops out between 120-125mph or so.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  15. #15 Re: Snapped Input Shaft
    Nov 2008
    when converting to 3.29's? was there a noticable difference in performance? and how annoying is it that the speedo is off?
  16. #16 Re: Snapped Input Shaft
    QCA, IA
    Quote Originally Posted by BrokenRhythm View Post
    The speedo shouldn't be off, when you do a conversion you need to get the computer reprogrammed for the new gearing, otherwise the shifting would be all screwed up, too. You could also just get a different reluctor wheel to fool the computer, but I don't know if anyone actually does that anymore.
  17. #17 Re: Snapped Input Shaft
    TDCRacing
    Guest
    Right. I had put a cam and a lot of other stuff in at the same time. So i'm not sure exactly what i was feeling but yes there was a difference in acceleration.
    A lot of peoples issues with breaking the tires loose is greatly dependant on the type of street tire there using. I use a street tire with around a 280 TR rating. That's probably i did not have to much of a traction issue.. All i could do is chirp second real good.
    A turbo is different though.
  18. #18 Re: Snapped Input Shaft
    Barksdale AFB, LA
    It won't affect your speedo since the reluctor wheel is on the diff, which isn't being changed out. You do need to have the PCM reprogrammed so it will shift at the right points. Also, without PCM programming the PCM will think the tranny is slipping (since there's more reduction with 3.29 instead of the stock 2.93).
  1. Input Shaft ZZP or Intense?? 500 whp
    By supercatxr7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2009, 08:24 PM
  2. intense input shaft
    By nemesis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-14-2008, 02:54 PM
