Thread: Transmission noise at idle
Results 1 to 12 of 12
  1. #1 Transmission noise at idle
    Jun 2018
    Long Beach, MS
    Trying to figure out what this noise is. I thought it was valve train noise but does not sound like it. Noise does not change putting in drive.
    Noise - YouTube
  2. #2 Re: Transmission noise at idle
    Does it change if you rev the motor in park?
    Thinking of how things work.. the only part of the trans turning at idle like that is the torque converter. It kinda seems like the flex plate may be cracked. Or the bolts to the converter are loose.
  3. #3 Re: Transmission noise at idle
    Jun 2018
    Long Beach, MS
    I looked at the flex plate with it on the car. I can not see any cracks. The torque converter bolts are tight.
    Here is a video of it revving.
    Noise 2 - YouTube
  4. #4 Re: Transmission noise at idle
    when the flex plate cracks its not the outer edge, its the middle around the crank, really hard to see.
    you take the sc belt off and run the engine yet? you know to rule it out.
  5. #5 Re: Transmission noise at idle
    Jun 2018
    Long Beach, MS
    I took all belts off has the same noise.
  6. #6 Re: Transmission noise at idle
    if your sure its coming from the bell housing, unbolt the tc from the flex put the starter back in and fire it up. you should be able to pry /push the tc off the flex plate a bit so its not scraping as it spins.
    if the sounds gone you know its flex or tranny.
    iirc ive also heard if you bang on it it should ring, when broken they dont ring. not 100% sure on that tho.
  7. #7 Re: Transmission noise at idle
    Jun 2018
    Long Beach, MS
    I unbolted the torque converter from the flex plate noise did not change. What ever it is I think its making the flex plate make noise. Probably not a bad flex plate. When i video it the phone picks up more noise by the trans.
    It could be the phone. In person that noise is not as loud but you here it.
  8. #8 Re: Transmission noise at idle
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Starter gear rubbing flywheel ?
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  9. #9 Re: Transmission noise at idle
    SE Level Member bcmonzai's Avatar
    Surrey, BC
    Here is a video of what my cracked flexplate sounded like before I fixed it:
    http://vid1230.photobucket.com/album...ps8fe0fa74.mp4
    2000 GTP Silvermist Coupe - GMR Torsen, Cartuning trans pan, GMPP Lowering & Handling Kits, TOGs, Corsa, Racetronix, GXP Brakes, Eagle Alloy 077s, HPTuners, etc.
  10. #10 Re: Transmission noise at idle
    If you unbolted flex from converter and still got the noise, then it's most likely the flex. I can't think of anything else that would make that racket.
  11. #11 Re: Transmission noise at idle
    Jun 2018
    Long Beach, MS
    Quote Originally Posted by cheatah faheatah View Post
    Its not the starter.
  12. #12 Re: Transmission noise at idle
    Jun 2018
    Long Beach, MS
    If it is the flex plate i would think the noise should change putting it in gear.
    I here the noise mainly at the front timing cover and at the trans.
  1. Trans noise, even when idle?!?
    By zql8tr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-08-2012, 10:07 AM
  2. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  3. 01 GrandPrix GTP S/C noise (not idle)
    By rwilsonGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2011, 08:00 PM
  4. odd noise during idle
    By xsvtank in forum General Tech Discussion
    Last Post: 06-16-2010, 09:29 PM
  5. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
