Thread: HD Differential question
Results 1 to 5 of 5
  1. #1 HD Differential question
    Sep 2015
    DE
    Is there a difference between the GTP and GXP differentials. My GM catalog shows different part numbers for the differentials. The extension housing and internal differential carrier gear are the same part numbers as the GTP, so it would seem you could interchange the differentials?
    The reason I am asking is I removed the planetary gears to replace the trapped Torrington bearing, left for the day. Next day, I found someone "cleaned up the bench". I had them in order of removal, now they are in random order and I thought I remembered that they need to be put back in the exact location they came from. This is for a high HP build, so I did not want to chance anything.
    I have a friend with some new in the box LS4 trans parts. A NEW differential, as well as a NEW input carrier and a NEW reaction carrier. He needs a few favors, so I can get these for no out of pocket expense (just my time), so if these will work, I may make a deal for them. I seem to remember the input and reaction carrier listed in the GM Racing build book they could be used as is, but I have personally never heard of anyone upgrading these. I can not find any info on using the differential from a V8 trans in the V6 trans at all.
    Thanks in advance for any help.
  2. #2 Re: HD Differential question
    hangover park IL
    i havent found anything dimentionally different, what i have found is that GM/others had improved the PM/sinter processs to improve the strength of helical gears that are harder to make using PM/sinter than straight tooth gears
    this is not the one i remember reading but it has much of the same info/keywords
    https://www.capstanatlantic.com/app/...ticle-2004.pdf
    ~James~ Psychotic Gearhead
  3. #3 Re: HD Differential question
    Sep 2015
    DE
    So if I am understanding what you are saying is, they should fit and work fine, and they use the improved PM process for better durability?
  4. #4 Re: HD Differential question
    I once moved a GXP trans into a standard SC casing and used all the parts except valve body/channel plate and electronics. The diff fit perfectly fine.
  5. #5 Re: HD Differential question
    Sep 2015
    DE
    Thanks guys. I will move forward with this.
  1. EP Differential??
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2020, 07:46 PM
  2. Differential
    By thekidinbuff in forum Wanted To Buy - Parts
    Last Post: 07-11-2018, 09:30 PM
  3. simple differential question
    By m17davis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-12-2014, 06:35 PM
  4. Differential question
    By Raviaan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2012, 09:24 AM
