I bought a 06 gt with good engine and trans . will this trans swap or do I also need pcm bcm....wiring ?
It could swap but you'd need to tune the computer to run the different gear ratio in the transmission. You'd also have to swap passenger side axles.
The NA cars run like a 3.05 gear ratio and the GT's run a 2.93 gear ratio.
I also have the pcm and bcm as long as I don't have to change wiring if I can be the bcm I assume the key won't work
