Thread: Want To Add Trans Cooler
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 Want To Add Trans Cooler
    May 2012
    Canada , Sarnia
    I just recently picked up a 2006 Grand Prix GXP and want to add a good trans cooler what do you guys recommend ?
  2. #2 Re: Want To Add Trans Cooler
    Jun 2017
    Indianapolis, IN
    Tru cool max on ebay for $118 on ebay. Also would instal a transgo shift kit too with filter and new fluid too.
    Sent from my SM-G930P using Tapatalk
  3. #3 Re: Want To Add Trans Cooler
    May 2012
    Canada , Sarnia
    Ok another question between researching up trans coolers what is better the inline or bypass coolers
  4. #4 Re: Want To Add Trans Cooler
    New York
    Run the cooler as a stand alone outside of the stock GM in radiator cooling. I have been running trans coolers as stand alones for 35 years and have never had a tranny failure. My 01 GP uses (2) long/dana coolers (18,000 GVW each), total cooling 36,000 GVW, for 120,000 miles now with zero issues. DD GP 365 days a year in very hot and very cold weather.Tranny still perfect at 205,000 miles.....
  5. #5 Re: Want To Add Trans Cooler
    May 2017
    Dirtyzville, Mizzery
    Tru-Cool 4590.
    Bypass the radiator.
    Done and done.
    1999 Chevrolet Silverado K1500 Classic Z71 - Intake/Gibson Exhaust/20% Tint
    2004 Chevrolet Corvette MRM A4 - C5Z Suspension/AFE S2 Intake/TSP Catless LT's/3" ORX/C6 ZR1 Wheels
    Sold WBody's: '98 GT, '98 GTP, '03 GTP, '05 GXP
  6. #6 Re: Want To Add Trans Cooler
    May 2012
    Canada , Sarnia
    ok I was looking at the one bkirwin recommened does that one also bypass the rad ? heres the link
    http://www.ebay.com/itm/Tru-Cool-Max...dWr6RW&vxp=mtr
  7. #7 Re: Want To Add Trans Cooler
    Jun 2017
    Indianapolis, IN
    Does not have bypass, but on ebay for another $37. I'm getting the bypass kit as well.
  8. #8 Re: Want To Add Trans Cooler
    May 2012
    Canada , Sarnia
    Going to order the Tru Cool 4590 off amazon tomorrow and to bypass the rad is there a bypass kit I need to buy or tell the shop I'm taking it to tell them I want it to bypass the rad ??
  9. #9 Re: Want To Add Trans Cooler
    Oct 2014
    portland oregon
    A shop should be able to figure it out. Or call them and ask. Or diy and save the money.. Its a easy thing to do.. I know because I did mine with no issues. If it can be messed up then ill mess it up every time.. Granted I have gtp not gxp but thats tit for tat lol
  10. #10 Re: Want To Add Trans Cooler
    Jul 2010
    Coquitlam,BC,Canada
    B&M #70264 has the low temp bypass built in.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Want To Add Trans Cooler
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by jbamonte View Post
    Run the cooler as a stand alone outside of the stock GM in radiator cooling.....My 01 GP uses (2) long/dana coolers (18,000 GVW each), total cooling 36,000 GVW, for 120,000 miles now with zero issues.
    Do either of your coolers have a low temp bypass?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Want To Add Trans Cooler
    I break stuff selliott's Avatar
    Kansas City
    I use the tru cool 4590 on mine it's easy to bypass the rad btw
  13. #13 Re: Want To Add Trans Cooler
    May 2012
    Canada , Sarnia
    What are your trans temp after the cooler install
  14. #14 Re: Want To Add Trans Cooler
    New York
    Yes, both coolers have built in temp control:
    Tru-Cool LPD Transmission Oil Coolers. Protect Your Investment—and Your Warranties.
    You can extend the life of your transmission and reduce the risk of costly repair bills with Tru-Cool LPD transmission oil coolers. By maintaining lower operating temperatures, you can significantly extend the life of both your transmission and the lubrication that keeps everything running smoothly.
    Drive hard. Rest easy. Get the OE advantage that comes from a Tru-Cool LPD transmission oil cooler, as well as the proven cooling that can help you protect the life of your vehicle.
    • 30% more cooling than traditional tube and fin design
    • 15 times less flow restriction that tube and fin
    • Self-regulating for maximum cooling and running protection
    • Durable brazed aluminum construction with a lifetime guarantee
    • Available in stacked plate or fin and plate designs
    • Available in 13 sizes
    Summer temps during hot weather are 135-140 tops and 125 degrees in the winter....coolers have been on the tranny for 130,000 miles and counting..........car driven all year round and in very cold weather.
  15. #15 Re: Want To Add Trans Cooler
    May 2017
    No LS4 is running 125-140* on the transmission. Mine was usually in the realm of 160-180*...even beating on it. That was with a new built TEP trans and a Tru-Cool 4590 bypassing the radiator and a finned trans pan. LS4 heat is worlds more than any 3100/3800 puts out.
  16. #16 Re: Want To Add Trans Cooler
    New York
    And your point is about the LS4?????
  17. #17 Re: Want To Add Trans Cooler
    May 2017
    Well the OP has an LS4, so what good does any other engine temp range do?
    LS4 generates a lot of heat.
  18. #18 Re: Want To Add Trans Cooler
    New York
    The LS4 I assume uses a beefed up 4T65E-HD (if there is such a thing). I currently have 3 cars with Long Dana Coolers of different cooling effectiveness. On my Mustang GT 5.0 V8 (325 NET HP/360 Ft-lbs TQ with the ford auto tranny, I had to go to 42,000 GVW cooling capacity and that tranny also runs in the 135-145 temp. The AODE tranny ran very high temps when cooled by the radiator only before the external coolers doing all the cooling. You need to size the coolers to meet the heat reduction requirement. All my cars with tranny coolers run in the 125-145 range easily, even under severe load. Put (2) 28,000 GVW coolers in the nose of the LS4 and I guarantee that the tranny temps will be in the 125-140 range. How do I know? From doing it on the mustang tranny...
  19. #19 Re: Want To Add Trans Cooler
    May 2017
    Apples and oranges.
    It won't ever stay that cold.
    Go buy an LS4 car and find out...factory temps soar north of 220* on average.
    And no, there isn't anything much different in it than a Comp G TAPShift transmission. That's why they always fail; from excessive heat breakdown. The 4590 is rated at 28k by itself. It doesn't need two coolers.
  20. #20 Re: Want To Add Trans Cooler
    Dec 2013
    Enfield
    My LS4 stays that cold in the cold of winter(110 to 120 degrees 45 minute commute), Hayden 679 trans cooler inline with the factory cooler. Average summer temp is around 180, before the cooler was added it would reach 220 easy. I don't drive it in the winter anymore, but those temps were too cool in my opinion .
  1. Tep Trans cooler
    By Suaveat69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-09-2015, 12:08 AM
  2. how to add a trans cooler
    By DirtDog in forum General Tech Discussion
    Last Post: 09-17-2012, 09:14 PM
  3. how to add a trans cooler
    By DirtDog in forum How To Write-Ups/Tech Tips
    Last Post: 09-17-2012, 08:54 PM
  4. trans cooler and oil cooler
    By mhartwig in forum General Tech Discussion
    Last Post: 11-17-2010, 10:33 PM
  5. trans cooler?
    By boostedgtp2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2010, 08:45 PM
