Thread: Transmission slips during left turns
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Transmission slips during left turns
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by lundellba02 View Post
    The 2-3 3-4 install sounds easy, but the 1-2 sounds like it requires a little more work. Either of you know about how long it takes to do the FULL install?
    What scotty said. My buddy did mine (tech for 20+ years) for me. Took him about an hour, while we shot the ****, sandblasted some of his parts etc., basically taking his sweet time.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #22 Re: Transmission slips during left turns
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    BTW. a common issue with these transmissions is slippage on a hard left. Ensure the fluid is right to the very top of the full mark on the dipstick to keep this from happening.
    Also glad that the shop took care of you on the loose filter. You'll notice that any time you buy a filter kit it typically contains a crappy gasket and a fresh collar. You only need to install the collar if the filter is loose when you put it in.
  3. #23 Re: Transmission slips during left turns
    SE Level Member Transman304's Avatar
    Jan 2017
    West Virginia
    A lot of filter issues with all make over the past few years. A lot of Chinese made filters just don't fit. Also no ill effects from over filling this trans up to 16oz. Good luck!
    Brad
    "If you can't fix it with a hammer you have an electrical problem"
    Like us on Facebook @ " Otto Matics"
  4. #24 Re: Transmission slips during left turns
    SE Level Member 1969n2o's Avatar
    Mar 2016
    Make sure your axles all the way in, idk if you recently changed it but if its not all the way in it can do that
    Sent from my SM-G920V using Tapatalk
  5. #25 Re: Transmission slips during left turns
    Donating Users
    Jul 2016
    Youngstown Ohio
    Scottydoggs where did the trans come from. I recently purchased a 01 GTP motor (bottom end noise) with transmission, trans from RockAuto. So I contacted them with serial number. They replied trans purchased in 2014 for a 01 GTP, (when I went to pick up I took passenger side axle 39 splines non HD only 33 and it fit. Pretty happy with purchase. Just have to get rid of motor.
  6. #26 Re: Transmission slips during left turns
    i got the rebuilt one from a member here, hes got a line of people wanting trannys, but hes undecided if hes doing any more.
  7. #27 Re: Transmission slips during left turns
    Donating Users
    Jul 2016
    Youngstown Ohio
    OK was thinking after swap to get OE one done up right.
  8. #28 Re: Transmission slips during left turns
    TEP is pretty much the go to place. they can do whatever you like. depending on how deep your pockets are, you can break 3 g's fast.
  1. Transmission Slips When Taking off Hard (How long do I have left)
    By indygrandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-21-2013, 12:06 PM
  2. slips on left turns...
    By m17davis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-26-2012, 07:09 AM
  3. Replies: 4
    Last Post: 06-20-2010, 04:04 PM
  4. Transmission slips bad at WOT
    By Rather B Blown in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-13-2009, 07:08 AM
  5. help transmission whines and slips
    By joswo in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-16-2009, 01:48 AM
