Thread: 99 Regal GS transmission interchange
Results 1 to 8 of 8
  1. #1 99 Regal GS transmission interchange
    Feb 2017
    FL - Florida
    Hello all, I have scoured the internet to find a definitive answer to my transmission compatibility question. I came across a post on here where someone put a 2005 comp G tapshift trans into a 99 gtp by simply replacing the ecm with a 03 gtp ecm and reusing the old range switch. Well my trans has 212k on it and it's tired. We have a pick your part here with a couple 06 gtps that I would love to snag the trans from to put in my 99 GS. Has anyone successfully replaced a 98-02 4t65e-hd with one from a 03-06? If so what did it entail? Thanks in advance, Nick.
  2. #2 Re: 99 Regal GS transmission interchange
    its not the same electronically. valve bodys different too iirc. and a gomp g tranny wont work at all if the cars not a comp g.
    97-2000 iirc is a direct swap. as long as its got the external pnp switch it will work. the 01 up have it internally, that you can swap over to make work. 03 would be the very end of the line for years to use.
  3. #3 Re: 99 Regal GS transmission interchange
    Feb 2017
    FL - Florida
  4. #4 Re: 99 Regal GS transmission interchange
    Feb 2017
    FL - Florida
    I definitely appreciate the info for sure Scotty. I have sucessfully converted a 4l60e and 4l80e to operate without issue on a couple 03+ GM trucks but I have been out of the trans rebuilding scene for quite some time now.
  5. #5 Re: 99 Regal GS transmission interchange
    Feb 2017
    FL - Florida
    I don't mind swapping my valve body and channel plate (if necessary). I would probably need a separator plate if these trannys are as hard on the plates as a 4l60 is. But I don't want to reuse my pump because it has seen better days. I found a reman delco pump for 160 but that's how much the entire trans will cost from the yard. Any idea if the newer pump would work on the older valve body/channel plate?
  6. #6 Re: 99 Regal GS transmission interchange
    SE Level Member Monday's Avatar
    May 2012
    Danielleland
    That post is quite interesting and not one that I noticed in the past.
    I have done the valve body and channel plate including seperator swap and it works well. the pump is interchangeable, pump shaft is not though. you'll notice the moment you button it up that the shaft won't spin if you have the wrong one.
  7. #7 Re: 99 Regal GS transmission interchange
    Feb 2017
    FL - Florida
    Ok that's good news. So I just need to retain the pump shaft and pump from the new unit plus swap over the vb and channel plate and all will be well?
  8. #8 Re: 99 Regal GS transmission interchange
    Feb 2017
    FL - Florida
    Ugh I just backed out of the driveway, put it into D, and got a free revving motor. It's toast. So it looks like I will be doing the swap this weekend.
  1. 2003 Chevy Monte Carlo Transmission Interchange??
    By bigmyyke in forum Introductions/Noob Questions
    Last Post: 06-07-2013, 01:12 PM
  2. regal gs transmission shudders from stop
    By Regalgs98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 02:08 PM
  3. gtp/regal transmission
    By jaygtp98 in forum General Tech Discussion
    Last Post: 07-20-2011, 08:44 AM
  4. Transmission Slipping on 97GTP. Interchange?
    By the496rocket in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-09-2011, 03:46 PM
  5. transmission interchange?
    By kaptainkx in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-02-2009, 12:03 PM
