Thread: Transmission Oil Leak at Radiator
Results 1 to 7 of 7
  1. #1 Transmission Oil Leak at Radiator
    SE Level Member mavmannate's Avatar
    Feb 2017
    KS
    Hello
    I have a transmission oil leak where the line connects to the radiator. I'm not sure yet if it's the upper or lower.
    I'm looking at rockauto and see the below pictures on parts. One is the radiator and one is the part thats on the radiator for the quick connect lines. Does anyone know if the bolt/o-ring picture i have below, is this stock on all of our radiators?
    Thanks.
    Transmission Oil Leak at Radiator Attached Images
    2006 Pontiac Grand Prix GT - 251000 miles - original transmission - original motor
  2. #2 Re: Transmission Oil Leak at Radiator
    what i would do is look up the trans line, cause thats whats is most likely leaking. unless you played with it, then un hook it and push it back in, its held in by a clip
    when the part on the rad leaks it leaks coolant. see the o ring on the back, thats what seals the coolant inside. it threads into the trans cooler in the rad.
  3. #3 Re: Transmission Oil Leak at Radiator
    Feb 2017
    KS
    I see what you're saying. I think what I'm going to do is replace it all. Both lines and the 2 connectors on the rad and the two connectors on the trans. I know what part i need for the connectors that thread into the radiator, however is it the same two connectors on the trans? I'm seeing conflicting info on parts websites.
  4. #4 Re: Transmission Oil Leak at Radiator
    old style is screw in like this, new is a push lock like the radiator.
  5. #5 Re: Transmission Oil Leak at Radiator
    Feb 2017
    KS
    When you refer to "old" style, are you talking about pre 2000's? Mine is a 06 and I'm pretty sure mine has quick connect.
    Am i correct in thinking I'll need one of each of these for the transmission side of things? First is the short fitting and the second is the long fitting.
  6. #6 Re: Transmission Oil Leak at Radiator
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    Mine was leaking and it was the orings on the fittings. I replaced them and the leaks stopped. That very well could be whats going on with yours.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  7. #7 Re: Transmission Oil Leak at Radiator
    Feb 2017
    KS
    Quote Originally Posted by LeadfootCJ7 View Post
    based on how inexpensive it is to change the fittings, im going that route. Rather knows its done right and not have to spend more time on it. Not to mention I think two leaks may be the problem. So I'm planning on doing hoses too.
  1. Radiator Coolant Leak near Petcock
    By buickman104 in forum General Tech Discussion
    Last Post: 12-24-2016, 04:34 PM
  2. Radiator Leak
    By argon0310 in forum General Grand Prix Discussion
    Last Post: 02-07-2013, 07:44 AM
  3. Small coolant leak. Radiator drain plug
    By eric37428 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-23-2013, 07:42 PM
  4. Transmission fluid leaking into radiator.
    By Fatboy58 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 10:24 AM
  5. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
