Thread: Used Transmission with Wrong Torque Converter?
Results 1 to 7 of 7
  1. #1 Used Transmission with Wrong Torque Converter?
    Jul 2016
    MO
    Bought a used transmission for me 99 GTP claiming to be from a GTP. My mechanic gets around to putting in the transmission today and says it fits but the torque converter is wrong. I'm wondering what you all think might be the case and answer some questions. Where are the markings on either the trans or TC that would identify whether or not it is a 65e or a 65eHD? If they are both from a 65eHD, what might make it not work? I've got a few days left on a guarantee, maybe I should just get my money back?
    Thanks in advance.
    '99 GTP Coupe - She runs, but she's not perfect.
    '97 GT Coupe - Sold in New Orleans
  2. #2 Re: Used Transmission with Wrong Torque Converter?
    pretty sure if you got both trannys side by side you see a difference in the axle tail and diff cover.
    if the diff covers are the same someone changed the tc to a na tc for the higher stall speed. and a na flex plate will fix your issue.
    if its not a hd tranny the gear change wont go over well with your pcm and unless you have a tuner to change the gears in the pcm it will blow its self up on ya.
  3. #3 Re: Used Transmission with Wrong Torque Converter?
    Easy way to tell is the diff on the passenger side, a GT axle doesn't fit in a GTP transmission because the length is different.
    They also look different.
  4. #4 Re: Used Transmission with Wrong Torque Converter?
    Donating Users timboku's Avatar
    Montgomery, IL
    What's the gm trans I'd say? Those numbers can tell you what it's out of.
    Sent from my SM-N910V using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  5. #5 Re: Used Transmission with Wrong Torque Converter?
    Jul 2016
    MO
    Quote Originally Posted by timboku View Post
    That is what I'd love to know how to find and decode.
    Sent from my Nexus 7 using Tapatalk
  6. #6 Re: Used Transmission with Wrong Torque Converter?
    Montgomery, IL
    Google....
    http://www.gmtuners.com/pda/4T65E-ID.htm
  7. #7 Re: Used Transmission with Wrong Torque Converter?
    Jul 2016
    MO
    They appear to be the same, do they not?
  1. Squeal from transmission or torque converter?
    By overdrive in forum General Tech Discussion
    Last Post: 07-07-2012, 10:48 PM
  2. Torque Converter
    By justaV6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2012, 08:09 PM
  3. How to install a torque converter onto the transmission
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2011, 11:40 AM
  4. New torque converter
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2010, 07:39 AM
  5. Torque converter ?
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 04:47 PM
