Thread: Transmission not engaging?
Results 1 to 10 of 10
  1. #1 Transmission not engaging?
    Sep 2016
    Flushing, MI
    can I ask some question of the veteran 3800 guys. Prolly best to post these in the transmisson category but not sure. Here it goes though...i was driving my 01 gp gtp yesterday to work...doing only 70mph when i got on it just alil to go around a slower car it front of me..(was using crusie control before this) well the slower car decided the guy in front of hom was the one holding us up and also wemt around the car in front of him so i left off as not to rearend the guy...i felt a tiny lil jerk or pop...hard to explain it..mostley in pedal though and went i went to gove it accel there was nothing. ..only high rev. Coasted to a stop and thats where it sat. I could feel it shifting into the gears including reverse but it wont go anywhere..it acts like its about to then doesnt (tiny movement when throttle applied, could just be engine making it rock). Transmisson was built for 600 hp...car sits at 400hp right now...
  2. #2 Re: Transmission not engaging?
    sounds like it broke a forward band or something.
  3. #3 Re: Transmission not engaging?
    If it doesn't even move in 1st gear, something big broke inside.
  4. #4 Re: Transmission not engaging?
    Mar 2014
    Tucson
    Quote Originally Posted by Bcriswell810 View Post
    What specifically was done? Sounds like a broken input shaft or chain. Could be a broken flexplate, but I imagine that would make an awful racket that would be clearly audible.
  5. #5 Re: Transmission not engaging?
    Sep 2016
    Flushing, MI
    Not sure..previous owner has biuld documentation but is out of state. No noise comes from trans..i can put the car in gear and it starts to engage but then doesnt..rolls fine in gear also
  6. #6 Re: Transmission not engaging?
    Sep 2016
    Flushing, MI
    Input shaft was done not to long ago i believe with a 300m
  7. #7 Re: Transmission not engaging?
    Mar 2014
    Tucson
    Time to start turning wrenches.
  8. #8 Re: Transmission not engaging?
    Sep 2016
    Flushing, MI
    I dont have the facilities to pull it or i would ....was hoping itd be something easily accessible but thats looking like its not going to be the case here lol
  9. #9 Re: Transmission not engaging?
    Mar 2014
    Tucson
    Yeah. I assume there's still fluid in it? Like, you didn't blow a cooler line and pump the thing dry? That's about the only "easy" fix with what you're describing.
  10. #10 Re: Transmission not engaging?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    maybe accumulator line came out? pull the pan and look, or maybe filter dropped out..hard to say
  1. 4th gear? not engaging
    By Dustoff in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-29-2015, 08:01 PM
  2. A/C not engaging
    By MattGTP04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2015, 11:58 AM
  3. ac compressotr not engaging
    By runn141 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2012, 07:42 PM
  4. A/C Clutch Not Engaging
    By ShadowSwept in forum General Tech Discussion
    Last Post: 07-01-2012, 09:31 PM
  5. noticed my TC is not engaging?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:27 AM
