Thread: 04 GTP Comp G (Tapshift) Trans Rebuild Differences
Results 1 to 6 of 6
  1. #1 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    SE Level Member GrandPrixGT300's Avatar
    Sandusky, OH
    Does anyone know if there are any differences in rebuilding the tapshift trans versus a regular 4t65e-HD?
    I'm looking to rebuild it and wondering if there is anything additional I need to know.
    Thanks,
    Andy
    99 GT (Stock - DD) & 04 Comp G (A Few Mods)
  2. #2 Re: 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    In general no, BUT you will need to get 4th friction plates that are referred to as "Internal and External One Sided Friction plates" and you will need two of each. This is special to all Volvo models and also the GM Tapshift transmissions. You will also need to order a new seperater plate from the dealer. These plates have bonded gaskets and the tapshift ones are unique. I never reuse the bonded plates as once the gasket has had an impression and been in service the gasket hardenes and wont properly seal so it needs to be replaced. The valve body and channel plate are unique to the tapshift transmissions also in case they need to be replaced. Otherwise it is the same as any other 4T65E internally aside gear ratio differences between models.
  3. #3 Re: 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    Sandusky, OH
    Thanks Dave, It looks like I'll be ordering pretty much everything from you. Do you have access to those additional parts that I will need? If so, do you have pricing on those parts.
    Thanks again,
    Andy
  4. #4 Re: 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    Fort Wayne, IN
    Yep no problem at all I can supply everything you will need for the build.
  5. #5 Re: 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    Sandusky, OH
    Just wanted to publicly thank Dave for all the help getting me the right parts and answering my probably 50 emails..haha I buttoned up the trans last weekend and it'll be installed next weekend. I wish all vendors treated customers this way.
    Andy
  6. #6 Re: 04 GTP Comp G (Tapshift) Trans Rebuild Differences
    Fort Wayne, IN
    Thanks Andy! I hope the trans works well for you
  1. LS4 V8 DoD 4T65-E TAPShift info
    By Sinister Performance in forum 5.3L V8 (LS4)
    Last Post: 12-29-2008, 02:32 PM
  2. Motor & Trans Rebuild Questions
    By BlackGhost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2008, 10:16 AM
  3. differences in tranny's
    By kbradley in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2008, 06:06 PM
  4. Looking for Trans Rebuild Info
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 12:03 AM
