Thread: 4T65e Tranny shift kit?
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21 Re: 4T65e Tranny shift kit?
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Quote Originally Posted by BoostedPontiac View Post
    I believe the max line pressure is 94 psi but i could be wrong. ZZP likes to keep the line pressure pretty high.
    So could doing a shift kit possibly hurt or not be good for the tranny with a zzp tune? That's basically what I was wondering if I can help it out a little without a rebuild and better parts I will but if it's not worth it I'll leave it alone.
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #22 Re: 4T65e Tranny shift kit?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I modified my ZZP tune but didnt change the trans tables when i added my shift kit. Its fine so far. Although i may have to add a little pressure on the 2-3 shift down low. Results may vary though.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  3. #23 Re: 4T65e Tranny shift kit?
    Jul 2015
    Jamestown, NY
    Okay good to know. In the transgo kit are there options like the different size zzp shims? Or is it just change the springs and what the kit is is what you got? Do you recommend any brand of tranny filter or it doesn't matter? I'm debating on sticking with delco tranny fluid since that's what's in there and it's fairly new.
  4. #24 Re: 4T65e Tranny shift kit?
    Apr 2014
    South Haven, MI
    The transgo kit is a single option kit which firms up the shifts and fixes what should have been done from the factory.
    I went with a ACDelco filter.
    Id change the fluid with new fluid. Just my opinion though.
  5. #25 Re: 4T65e Tranny shift kit?
    Jul 2015
    Jamestown, NY
    Okay thanks man. I'm going to change the fluid that's no question what I meant was I'm debating on using delco fluid or just something decent at the parts store. What did you use?
  6. #26 Re: 4T65e Tranny shift kit?
    Apr 2014
    South Haven, MI
    Valvoline synthetic ATF (dex equivalent)
  7. #27 Re: 4T65e Tranny shift kit?
    Jul 2015
    Jamestown, NY
    I'm looking up a ac delco filter and what's the difference between the gm tf304 and gm 24206433?
  8. #28 Re: 4T65e Tranny shift kit?
    I use a wix filter from napa, ac delco stuff is made in china I bet just like their oil filters.
    Dexron 3 is my fluid of choice, it's cheaper than dexron 6.
  9. #29 Re: 4T65e Tranny shift kit?
    Buffalo
    Lmao. This thread hurts my head
  10. #30 Re: 4T65e Tranny shift kit?
    Jul 2015
    Jamestown, NY
    Do you use just the regular 220 green scotch brite pads? Seems weird to me you want to scratch the bore.
  11. #31 Re: 4T65e Tranny shift kit?
    Apr 2012
    Goderich, Ontario
    I'm using the Intence kit with dex6 and an Overkill tune. I'd definatly buy the Intence kit again, very detailed instructions and included absolutely everything I needed except the fluid.
    -Paul Walker
  12. #32 Re: 4T65e Tranny shift kit?
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by Tonkin2000GT View Post
    The cylinders in your engine were "scratched up" from the factory in the form of cross hatching. It helps to the retain oil. It's common to do this and only takes a second you're not going to be in there a long time just scuff and move on. This is also X common on wheel cylinders back when most people rebuilt them instead of buying new.
  13. #33 Re: 4T65e Tranny shift kit?
    May 2008
    Schuyler, NE
    Running both a tune and shift kit without upgraded trans hard parts is a great way to break something. There is a lot of 13 second cars that break transmissions because they are shifting too damn hard.
    If it shifts well the way it is, I'd leave it be. I had very little done to the trans and tune when I was running 11's.
  14. #34 Re: 4T65e Tranny shift kit?
    Jul 2015
    Jamestown, NY
    Really leave it alone? that's what I was worried about
  15. #35 Re: 4T65e Tranny shift kit?
    Buffalo
    Email John at intense
  16. #36 Re: 4T65e Tranny shift kit?
    May 2008
    Schuyler, NE
    Better yet, get yourself a tuner and learn how to do it yourself. I like adjusting shift firmness through the tune much better. If you add a little more power, you can keep them just firm enough to prevent slipping too much between shifts, but not too firm as to break stuff.
    So many guys snap the input shaft on the 1-2 shift with a tune and shift kit.
    You don't need hard shifts. It's not a th400. And it will literally make you almost no quicker in the 1/4 mile.
  1. 4t65e Shift Kit
    By Jonarin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2015, 03:23 AM
  2. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  3. Tranny Swap 4T65E-HD to 4t65E
    By windowrattler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2012, 03:47 PM
  4. 4T65E HD tranny swap and perf. shift question
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 11:49 AM
