Thread: Possible Trans Issue 1998 GTP
Results 1 to 8 of 8
  1. #1 Possible Trans Issue 1998 GTP
    SE Level Member Nickster 7's Avatar
    Feb 2015
    United States
    Over the last few months, I've noticed that when I'm in third or fourth gear and I give some moderate throttle, I feel some sort of jolt from the car. It's a pretty hard jolt, enough to make friends wonder what's wrong with my car. It's strange, because if I'm driving at 55 on the highway, and I give the car 1/4 throttle or so, it's almost like the transmission is unlocking, and then locking back up really quickly, and it will do it about every second until I give more throttle to kick the trans down a gear. I have this issue in third and fourth gear. I don't think it's any kind of slippage, because I've done a full throttle pull to about 130MPH, and the trans does not slip at all in third gear.
    My car is a bone stock (for all I know) 1998 GTP with 102,000 miles.
    Current:
    1998 Grand Prix GTP
    1995 Camaro Z28 M6
    Sold: 1987 3/4 ton Silverado
  2. #2 Re: Possible Trans Issue 1998 GTP
    kinda sounds like your 4 th gear hub is worn out. or wearing out. what your feeling could be it slipping in and out of over drive.
  3. #3 Re: Possible Trans Issue 1998 GTP
    Also, speed limiter is 127 and 110mph in 3rd select with factory tune.
    It also is very bad for the transmission to shift into 4th at those speeds, just as a fyi.
  4. #4 Re: Possible Trans Issue 1998 GTP
    Feb 2015
    United States
    Scotty, if my car does the same in third and fourth gear, could the fourth gear hub be causing the issue in both gears?
    I had the car up to around 130, so maybe 125. I was showing a friend that my gtp was faster than his V6 Camaro, but another time I had 3rd selected (this is when I was testing the trans for slippage) and I hit the 110 limiter.
    But basically, at moderate throttle and when the trans is fully locked up, it almost feels like the car decides to downshift, but then changes its mind within milliseconds, causing the jolt.
    Current:
    1998 Grand Prix GTP
    1995 Camaro Z28 M6
  5. #5 Re: Possible Trans Issue 1998 GTP
    I'd hook it up to a live data scanner and be watching tranmission related pids/tables. It might be an issue with the TCC.
    Maybe even a stored code on the transmission side. But not everyone has a scanner like this.
  6. #6 Re: Possible Trans Issue 1998 GTP
    Feb 2015
    United States
    I don't own a scanner or really know anyone with one. I really just want to fix it for peace of mind. Other than this, the car has been more reliable than anything I've owned.
    I'm just not 100% positive that it's mechanically worn parts. Like you mentioned, I'm hoping just a solenoid or something stored in the computer.
    Scotty may be on to something though, because sometimes when the car shifts into fourth, there can be a delay. It could be two separate issues, but if I can get the jolting one fixed, that's all I care about for now.
    Current:
    1998 Grand Prix GTP
    1995 Camaro Z28 M6
  7. #7 Re: Possible Trans Issue 1998 GTP
    best to scan it, make it act up, then hit autozone, dont turn the car off, ask them to scan it for codes, its free. if you have a pending code it will clear when you turn the car off, so leave it running, bring a guard dog or friend to watch the car.
  8. #8 Re: Possible Trans Issue 1998 GTP
    Feb 2015
    United States
    Yeah, I have an AutoZone nearby. I'll see what I can do (when I have time) and post my information back to the forum. Thanks for all of the suggestions guys!
    Current:
    1998 Grand Prix GTP
    1995 Camaro Z28 M6
  1. Weird speedometer issue, possible trans issue?
    By Peder in forum General Tech Discussion
    Last Post: 07-28-2014, 07:08 PM
  2. 1998 GTP Trans Removal
    By DirkJr in forum Introductions/Noob Questions
    Last Post: 04-18-2014, 06:17 PM
  3. 1998 GP GT Transmission Issue
    By Kentus in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2010, 09:46 PM
  4. 1998 Trans in 2001 car
    By oldsman105 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2008, 12:21 AM
