Thread: what do i need to replace
Results 1 to 8 of 8
  1. #1 what do i need to replace
    Nov 2008
    iowa
    im thinking of rebuilding my tranny. what do i all need? transmission kit, how about the solenoids?
  2. #2 Re: what do i need to replace
    Banned
    Wichita Falls, Texas
    I'd replace the solenoids, clutches, get a hardened 4th clutch shaft, hardened pump shaft, upgraded input shaft to the level you need, shift kit, and gears with a single chain. Check the diff and replace it too if need be.
  3. #3 Re: what do i need to replace
    Nov 2008
    iowa
    what is the cost of all the stuff? this will be my first time doing this. could i get away with just putting the clutches in and the solenoids?
  4. #4 Re: what do i need to replace
    TDCRacing
    Guest
    Well what you ''could get away with'' would more than likley depend on what is messed up or worn out in it right now.
    I would do it right and do a full rebuild on it to save you time and money on it in the future.
  5. #5 Re: what do i need to replace
    Nov 2008
    iowa
    where can i find the stuff at? ebay?
  6. #6 Re: what do i need to replace
    TDCRacing
    Guest
  7. #7 Re: what do i need to replace
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    There is really no set list of what you will need but there is a lot of parts that should be or is recommened to replace during a rebuild. You arent going to know exactly what parts to get until the trans is apart. Is your car stock or is it modified and if so what is done to it? How far do you plan to take it?
  8. #8 Re: what do i need to replace
    Nov 2008
    iowa
    i aint gonna be racing it just a car for driving. i'm gonna leave it stock
  1. CV Shaft Rebuild/Replace [*]
    By Reptile in forum How To Write-Ups/Tech Tips
    Last Post: 11-06-2009, 02:04 PM
  2. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  3. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
  4. How hard is it to replace tie rod ends?
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2008, 10:55 PM
  5. Replace cam bearing with engine still in?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2008, 09:05 PM
