Thread: Tranny thread fitting Information
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Tranny thread fitting Information
    Jul 2012
    Midwest
    I may not have understood everyone correctly, but does that mean that a 99 trans from a 3.8 is not a direct interchange to a 2002 with a 3.8?
  2. #22 Re: Tranny thread fitting Information
    You need to look to see if you have threaded transmission lines or the click style. If they are not threaded, they are click. If they are click, then you are interchangeable.
  3. #23 Re: Tranny thread fitting Information
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    I bought a trans from Triple Edge but it came with the older style threaded fittings. The older trans took 9/16x18 and 5/8x18 fittings size. I do not know what year the trans came from.
    My 04 GT had screw in adapters with quick disconnects fittings for 3/8 lines. Both feed and return were the same thread size (although one is short and the other long).
    I ended up having to buy Dorman 800-605 and Dorman 800-619 connectors to adapt my quick connect fittings on my 04 GP lines to the older screw trans. Took me a long time to figure this one out. Hope it helps someone else out.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  4. #24 Re: Tranny thread fitting Information
    Medford, OR
    OK, I read through the sticky, and didnt see an answer for my problem. My daughter wrecked her 2000 GP, then went out and picked up a real nice 99 with a bad motor. So, I have yanked the good motor out of the 2000 (with tranny), and stuffed it back into the 99. The fittings for the tranny cooler lines for the radiator ends were too big, so I went to swap them with the lines off the old motor-and that doesnt seem to work either. Is there a quick and easy fix to get lines that will fit the 2000 tranny (with check valve) and the 99 radiator?
    I might add that they are both 3.8GTs. The 2000 is a 4 door and the 99 is a coupe.
  5. #25 Re: Tranny thread fitting Information
    Medford, OR
    No one?
  1. Transmissions fitting
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2009, 09:00 PM
  2. brake line fitting ?
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 06:42 PM
  3. Trans pressure test port fitting
    By Sabrewings in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-17-2008, 11:01 AM
  4. Fitting a double din reciever into 00 grand prix
    By robahr24 in forum Audio, Security & Visual Electronics
    Last Post: 01-26-2008, 11:57 AM
