Thread: exessive shifting
Results 1 to 19 of 19
  1. #1 exessive shifting
    Jul 2013
    Lockeport Nova Scotia Canada
    I have a 2002 40th gtp
    I have the past few days began to notice that I have exessive shifting it seems, My Aeroforce Gauge I have it set to show what gear its in. It shows the gears but it seems to shift ( sounds like it goes to another gear without actually showing it on the gauge when it does even though it shows when it has actuyally shifted if that makes sense , I have noticed my Cruise control quit also , could this be related, I lso disconnectred the battery cable for almost 2 hours , took the car for a drive and it still seems to be doing the same thing , , WHat could be causing this ?
  2. #2 Re: exessive shifting
    Jul 2013
    what controls the shifting times ?
  3. #3 Re: exessive shifting
    Kemmerer, Wyoming
    pcm commands the shift. cruise control has its own control module, not related to the transmission at all. could be a bunch of stuff that cause's the cruise control to fail. not sure what would make your transmission act funny. hard shifts may not be a bad thing, but if it just started out of the blue with no tuning or changes from you, its probably not good. a fast shift is better because the clutches have less slip.
  4. #4 Re: exessive shifting
    Jul 2013
    this thing isnt doing hard shifting , just annoying what seems like going from one gear to another smoothly
  5. #5 Re: exessive shifting
    Mar 2014
    Tucson
    You will notice a change in RPM's when the torque converter clutch (TCC) engages and disengages even if you're not changing gears or speed.
  6. #6 Re: exessive shifting
    Jul 2013
    I will change the pcm tomorrow , I have a spare
  7. #7 Re: exessive shifting
    Jul 2013
    I see a very slight change in rpms
  8. #8 Re: exessive shifting
    after it shifts the rpm's will lower as the tc locks up then unlock as you hit the gas and get into it some.
    you can test the lock up by holding the gas steady on the highway, the tap the brake with your left foot, the rpms should rise 2 to 400 rpm. thats the tc unlocking. then it will lock up again and drop the rpm's.
  9. #9 Re: exessive shifting
    Mar 2014
    Tucson
    My guess it tcc, unless... Is all maintenance up to date? Clean MAF and all that....
  10. #10 Re: exessive shifting
    Jul 2013
    the tranny was rebuilt 14000 kilometers ago, I havent cleaned the maf sensor and stuff , I do have a couple codes come up on the aeroforce gauge. PO137 , and a P1133
  11. #11 Re: exessive shifting
    Jul 2013
    I did put a new air filter in last week
  12. #12 Re: exessive shifting
    Jul 2013
    as you describe how the TCC works, it almost sounds like this is what im having issues with, it it is , what do I do ??
  13. #13 Re: exessive shifting
    Mar 2014
    Tucson
    Address your codes first.
  14. #14 Re: exessive shifting
    Jul 2010
    Coquitlam,BC,Canada
    FYI, Aeroforce has a "TCC Slip" reading.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: exessive shifting
    Jul 2013
    thats one of the things I have programmed to show, how do I read it and what do all the numbers on it mean
  16. #16 Re: exessive shifting
    GXP Level Member
    Mar 2015
    Tomball
    The TCC will also unlock when you release the gas pedal so if you are constantly moving from cruise to let off the pedal it will lock and unlock. The TCC slip will show about 20rpm or so when locked up and when you release the pedal it will jump like Scotty said. My car does the same thing if I'm cruising in traffic and need to let off to maintain distance between myself and the car in front of me.
    Jeff
  17. #17 Re: exessive shifting
    Kemmerer, Wyoming
    someone correct me if I'm wrong, my understanding of how the TCC works is pretty much just like a clutch on a manual transmission, you push the clutch in so the engine is disengaged from the transmission and you coast. the tcc on an automatic can engage and disengage much faster than the clutch on a manual, the other factor to consider is the actual locking, when the engine is making power and you are driving down the road, when you are in 4th gear the torque converter will lock and that is how you go into overdrive, I think it can also do it in 3rd gear.
  18. #18 Re: exessive shifting
    GXP Level Member
    Mar 2015
    Tomball
    Pretty much, but you still have a slight amount of slippage which I am told is normal and is to deal with NVH issues. Personally I don't understand why GM still uses a clutch. It would be so much more effective and efficient to lock the turbine shaft and the stator, but it is what it is. In one of the threads a couple of the guys mention tuning this out, by increasing the PW to 100% or something.
    Jeff
  19. #19 Re: exessive shifting
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by PipeOrganDaniel View Post
    Haven't got a clue. I've only looked at it once; had #'s from 0 to 7900.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. Shifting w/o key on?
    By bobabooie in forum General Tech Discussion
    Last Post: 02-21-2011, 08:33 PM
  2. serious shifting
    By 99prixgt in forum Off Topic Discussion
    Last Post: 01-15-2011, 05:34 PM
  3. 2 to 3 tranny shifting & WOT shifting problems
    By josh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 08:52 PM
  4. car not shifting right??
    By Joe m in forum General Tech Discussion
    Last Post: 02-02-2010, 08:50 PM
  5. Another shifting from CGP
    By gp2000gt in forum Introductions/Noob Questions
    Last Post: 01-28-2008, 04:07 PM
