Thread: 4T80 Year specific question
Results 1 to 19 of 19
  1. #1 4T80 Year specific question
    Banned
    CT
    Quote Originally Posted by SnowFlake View Post
    so which year/make/model is the best to pull a 4t80 from?
    Quote Originally Posted by Turbocharged400sbc View Post
    Lulz
    what year depends heavily upon what year PCM you're using and whether you want to make a hybrid with the internal mode switch to solve the external range switch clearance issues
    Assuming I'm working with a PCM from my 2000 Regal?
  2. #2 Re: 4T80 Year specific question
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    I have access to two already pulled out good 4t80e trans but they are 1994.
    Is that a good year.
    Like Snowflake said what's the best year, anyone know ?
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  3. #3 Re: 4T80 Year specific question
    Arizona
    Thought itd be worth mentioning with T42 trans controller that later LS4's and other various gms have have the option to change shift solenoid patterns in the software via HP tuners which should allow you to just use the caddy parameters and just drive.
  4. #4 Re: 4T80 Year specific question
    hangover park IL
    youll want a 97-99 80e though you can use later years with some trial and error, later 80e's have the IMS to elim that issue, its easy as hell to swap the harness and IMS in (ive got one ive removed already, boxed up and ready for the 442) i never got too far into the lack of a tcc pressure switch, presumably you can delete the code diagnostic and the tcc will function just without triggering the code and the hot/failsafe stuff.
    Quote Originally Posted by TwinV6GTP View Post
    the early had issues with the castings warping so many of those are GM reman. you do not have the pressure switch manifold so your gonna have some work to do with the obd2 pcm but your trans controller likely doesnt have any diagnostic capability so it wont use em. we have a nearly new GM reman from a 94 deville with 165 on the clock, trans probably has maybe 20k barely any oil staining on the GM grey paint and even the alum reman tab wasnt corroded. i will swap out the vb and harness if i have to, regardless its a goldmine of new parts.
    Quote Originally Posted by 91parkave View Post
    ive wanted to play more with the trans type in tiny but ive got two 80e pcm's here that id love to see if i can pull any data from. i kinda wonder if changes in the bin file might be affecting overall trans strategy...its possible he just has a weak trans so im interested in what dave finds out. the inverter never had any issues aside from ****head not sealing it up against saltwater.
    i never got dave to tell me exactly what he did with the bin file lol maybe he can take care of the pesky tcc switch issue (though manual operation works fine)
    ultimatly you suckers are helping jeff, me, dave, and the canuckian's, blaze the trail.....hahahah
    thanks! lol
    ~James~ Psychotic Gearhead
  5. #5 Re: 4T80 Year specific question
    GT Level Member aligater's Avatar
    london ontario canada
    Who would the canuckian's be referring to?
    Edit Nvm I figured it out.
  6. #6 Re: 4T80 Year specific question
    Banned
    CT
    I'm more and more intrigued by the 80e swap every day.
    I just shattered the 3rd gear sprag in my ultimo65e build... kinda blows since there's no upgrade for the sprag.
  7. #7 Re: 4T80 Year specific question
    Trans grenade again? Second time this summer flake?
  8. #8 Re: 4T80 Year specific question
    Banned
    CT
    No, it's been mint all summer until this.
  9. #9 Re: 4T80 Year specific question
    Hmm thought it popped before anyways yeah looking at the chain and diff setup on the 4t80 makes me want to choke all the gm engineers for not putting this behind a sc 3800 from the get go.
  10. #10 Re: 4T80 Year specific question
    Banned
    CT
    No I had a problem with 3rd gear holding on big boost but turned out I just needed to add a qt of fluid.
  11. #11 Re: 4T80 Year specific question
    May 2013
    Gatineau
    I'll put the 4t80e to the test. So far it's much stronger than a stock 4t65-hd for sure. I have enough test runs + a solid 60 foot on it to prove that.
    But is it stronger than full built 4t65-hd ? Too early to tell.
    So far my impressions are much better power output at the wheels. It just seems to make power effortlessly to the wheels while the 4t65-hd was always on the converter and or always felt like it slipped at full power too.
    But that tight converter is a ***** too, can't make decent boost until at least 3 seconds. Best boost at 4 seconds WOT. That makes it difficult to stage in my opinion.
    Modifying the timing curve and fuel curve at spool up results is lower boost output. The current timing curve produces the best RPM and boost.
    The stock Deville converter engages at 1600rpm and with 3 full seconds on the throttle 2700RPM
  12. #12 Re: 4T80 Year specific question
    hangover park IL
    I'm telling you get the Aurora converter... 4.0 liter.
    I'd sell you mine but I need it so **** you lol
  13. #13 Re: 4T80 Year specific question
    hangover park IL
    the converter bolt pattern is the same
  14. #14 Re: 4T80 Year specific question
    May 2013
    Gatineau
    I cant drop
    The trans now ill work with what i have. Business is getting super busy im out of time on this personal project
    Sent from my iPhone
  15. #15 Re: 4T80 Year specific question
    hangover park IL
    lol no worries bud.
    its been 14 years for us at this point. the aurora converter i have i pulled from a wrecked car with a minty drivers seat/pedals...took 2-3 hours in the junkyard....been doing crap like that to collect our parts for just hte last 3-4 years lol
    around here half the time they yank the N* and toss the 80e inthe trunk....makes it easy...sometimes
  16. #16 Re: 4T80 Year specific question
    Banned
    CT
    Someone build an 80e and drop it in my car.
    I'm tired, and very busy.
    But I wanna run 10s.
  17. #17 Re: 4T80 Year specific question
    hangover park IL
    We are shooting for low 8s
  18. #18 Re: 4T80 Year specific question
    Banned
    CT
    In the Regal???
  19. #19 Re: 4T80 Year specific question
    hangover park IL
    The 442
    The TR will hopefully get to the high 10's as a "street car"
    it will probably be a dyno queen just like all those slow ass high horsepower supras
  1. This goes out to all you Cadillac guys. 4t80 trans
    By theaceofspades in forum Off Topic Discussion
    Last Post: 12-30-2013, 04:19 PM
  2. Replies: 2
    Last Post: 07-01-2013, 12:58 PM
  3. 3800 - Swap 4T65 to 4T80
    By EarlT in forum General Tech Discussion
    Last Post: 09-28-2011, 03:36 PM
  4. body year question
    By PLAYTME in forum General Tech Discussion
    Last Post: 10-30-2010, 10:55 PM
  5. pacesetters are way better than SLP's...when running a 4T80-E
    By turbocharged406sbc in forum Off Topic Discussion
    Last Post: 04-01-2008, 02:20 AM
