Thread: 5-speed flywheel
Results 1 to 4 of 4
  1. #1 5-speed flywheel
    Dec 2012
    troll land
    how come everyone mills the flywheel insteady of using a spacer between the bellhousing and block seems like it would easier and cheaper in the long run and there is plenty of adjustment in the mounts plus u dont run the risk of a shoddy machinist just my curious thoughts and two cents
  2. #2 Re: 5-speed flywheel
    Mar 2012
    NC
    Cost of having a spacer made is typically higher than the cost of a flywheel. Yes, you do risk the machinist screwing it up (which is my problem) but the flywheels are cheap...especially when picked up at a junkyard.
  3. #3 Re: 5-speed flywheel
    Dec 2012
    troll land
    i can cut a plate out myself just wanted to know if it would cause other probs thanks
  4. #4 Re: 5-speed flywheel
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    It's going to change the mounting of the transmission, and affect the length you need for axles. Much easier to get the flywheel milled.
  1. Help!!! Flywheel won't turn!
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2011, 11:44 PM
  2. Engine swap, Starter/flywheel problem
    By awesomefullness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 07:48 AM
  3. Flywheel position
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 09:34 AM
  4. is the flexplate the same thing as the flywheel?
    By 98bdgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-19-2009, 12:50 PM
