Thread: 04+ Manual
Results 1 to 15 of 15
  1. #1 04+ Manual
    Nov 2011
    Bloomington IL
    Just throwing it out there, but has anyone done one yet?
    05 GTP. K&N Intake and magnaflow mufflers, plog-cross-rear exhaust with 3' DP. (Soon to be 3.6 and ported SC)
  2. #2 Re: 04+ Manual
    GT Level Member GtpKo's Avatar
    Best place on Earth
    I believe it hasn't been done on an 04+ yet. The only difference would probably be the aluminum subframe not having mount holes for the 284. It was recently done to a 2000 Impala over on NAIOA: http://www.naioa.com/v2/modules.php?...wtopic&t=47570
    Somebody with a 3rd gen, time, cash, and will, needs to step up to the plate for all of us dreamers. Please?
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  3. #3 Re: 04+ Manual
    Mar 2012
    NC
    The F40 requires a lot of custom stuff...the 284 could be done with a steel subframe. I just did my 284 swap...it's a lot of work. Especially when the trans is toast and I need to find another one.
  4. #4 Re: 04+ Manual
    Nov 2011
    Bloomington IL
    Once my bank account says I can, I plan to be the first one to do it. Either a Getrag 284 or F40, whichever is easier to obtain. Im banking around $6,500 for a shop to do it. You all think that sounds about right?
  5. #5 Re: 04+ Manual
    Mar 2012
    NC
    With the amount of fab needed, that'll cover the fab work.
  6. #6 Re: 04+ Manual
    Nov 2011
    Bloomington IL
    Quote Originally Posted by hitman92499 View Post
    $8,000 a bit closer?
  7. #7 Re: 04+ Manual
    Mar 2012
    NC
    Well if you buy the f40 swap on here then you'd have quite a bit towards labor. It isn't cheap and expect the car to be down awhile.
  8. #8 Re: 04+ Manual
    Nov 2011
    Bloomington IL
    So its easier to swap a 284 than an F40?
  9. #9 Re: 04+ Manual
    Mar 2012
    NC
    Neither really. The 284 is elusive...I know I'm trying to find one to replace mine now (for a decent price.) The F40 may be easier to source. Also, the amount of fab I have into my setup is ludicrous.
  10. #10 Re: 04+ Manual
    Nov 2011
    Bloomington IL
    Sweet lord.....I feel like no shop that doesnt charge at least $200 per hour would have no clue what to do
  11. #11 Re: 04+ Manual
    Mar 2012
    NC
    It's all trial and error stuff. Check out my build thread in the Member's Rides section. Look for the IncREDihoopdy 5 speed build.
  12. #12 Re: 04+ Manual
    Nov 2011
    Bloomington IL
    Your build just made me want to quit my job and do this conversion. I take it the Series II and Series III have the same bolt pattern for the transmission?
  13. #13 Re: 04+ Manual
    GT Level Member outonthetiles's Avatar
    Dec 2011
    Herkimer, NY
    Yep.
  14. #14 Re: 04+ Manual
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    I've owned an f40 04 comp g,
  15. #15 Re: 04+ Manual
    GT Level Member crazybrownklick's Avatar
    May 2011
    El paso tx
    Quote Originally Posted by kuntzie View Post
    Got any pictures would love to see it
  1. Service Manual?
    By JustinTime in forum General Tech Discussion
    Last Post: 04-09-2012, 05:34 PM
  2. manual conversion
    By kking89 in forum General Tech Discussion
    Last Post: 07-02-2011, 10:14 PM
  3. Manual Tranny?????
    By 305gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2009, 09:10 AM
