Thread: 5 speed in a ninety five?
Results 1 to 19 of 19
  1. #1 5 speed in a ninety five?
    SE Level Member Drifty's Avatar
    Jun 2010
    Fort Worth Texas
    ive been searching through the forum but have yet to find the possibilty of putting one of the five speeds in a ninety five gtp. anyone know if its been done?
    '95 GTP
  2. #2 Re: 5 speed in a ninety five?
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    its done and easy
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  3. #3 Re: 5 speed in a ninety five?
    GT Level Member sic6's Avatar
    san marcos, tx
    Some of the 91-94 se grandprixs with the 3.1 came with 5 spds from the factory.Look for those if possible to do your swap.
  4. #4 Re: 5 speed in a ninety five?
    Nov 2008
    Waterloo, Iowa
    People have done them in 97-03, they came in 1st gen W-Bodies, so I'll say definitely yes.
  5. #5 Re: 5 speed in a ninety five?
    Leominster
    The getrag 284 in the '91-'94 Grand Prixs were optional on the GTP's, STE's, and SE's...Designed to be the successor to the Getrag 282 (as found on pre-90 model year cars with the 2.8 & 3.1) and is more durable compared to the predecessor. So yes you can easily swap either the 282 or the 284 into your '95 GTP.
  6. #6 Re: 5 speed in a ninety five?
    Jun 2010
    Fort Worth Texas
    what all custom fab would be needed? (mounts, brackets for master and slave cylinders...etc)
    '95 GTP
  7. #7 Re: 5 speed in a ninety five?
    SE Level Member BobC's Avatar
    Chicago area
    So, I wonder then if anyone has done it on a newer one, like 97?
  8. #8 Re: 5 speed in a ninety five?
    kuntzie has done it.
    he says you basically need the car.
  9. #9 Re: 5 speed in a ninety five?
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by BobC View Post
    Nuff said.
  10. #10 Re: 5 speed in a ninety five?
    Jan 2009
    Tallahassee, FL
    I imagine in a 1st gen it's pretty easy since there are factory parts to do it. For 2nd gens it's a lot more custom work for mounts and such. I believe there is a mix of parts from a couple of different cars to get the axles and clutch to work.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  11. #11 Re: 5 speed in a ninety five?
    Feb 2010
    its not hard, you need 97 gt or se axles and you need to modify the master by making the clutch rod longer, you also need to make one weld for the clutch pedal
  12. #12 Re: 5 speed in a ninety five?
    Chicago area
    Would there be any problem with the computer on it not finding an automatic?
  13. #13 Re: 5 speed in a ninety five?
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by kuntzie View Post
    That's not that bad. I read about doing a 6 speed swap and the guy ended up going with custom length axles.
    You'd have to tune all of the auto stuff out.
    77 Morris Garage B
  14. #14 Re: 5 speed in a ninety five?
    Chicago area
    Quote Originally Posted by Sandman View Post
    Yes, but is that easily doable with the OBD II?
  15. #15 Re: 5 speed in a ninety five?
    Nov 2011
    Bloomington IL
    What about in a 3rd gen? 2004+ has anyone tried that before?
    05 GTP. K&N Intake and magnaflow mufflers, plog-cross-rear exhaust with 3' DP. (Soon to be 3.6 and ported SC)
  16. #16 Re: 5 speed in a ninety five?
    Dec 2012
    troll land
    wut about a 282 n a 97 monte
  17. #17 Re: 5 speed in a ninety five?
    Feb 2013
    Canada
    I have a 284 with ~110k miles and ALL the necessary swap parts (axles, shifter, cables, pedal bracket etc) from a '92 Z34 if anyone is interested. Also have a brand new clutch and flywheel from an LQ1 longblock. I tried posting this in the for sale section but I don't have enough posts yet. Let me know if interested. Thanks.
  18. #18 Re: 5 speed in a ninety five?
    Mar 2012
    NC
    Quote Originally Posted by SVTPaul View Post
    PM'ed
  19. #19 Re: 5 speed in a ninety five?
    Feb 2013
    Canada
    Quote Originally Posted by Sven Sexman View Post
    PM'ed
    Response sent.
  1. gt top speed
    By ionroller in forum General Tech Discussion
    Last Post: 03-04-2013, 03:04 PM
  2. Top Speed?
    By UCF04GPGTPCompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2011, 10:53 AM
  3. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  4. new and need some speed
    By redrebel82 in forum Introductions/Noob Questions
    Last Post: 07-22-2009, 09:31 PM
  5. top speed
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2008, 02:18 AM
