Thread: How the bleed the clutch on a Getrag 284?
Results 1 to 4 of 4
  1. #1 How the bleed the clutch on a Getrag 284?
    SE Level Member DanGrandPrix's Avatar
    Oct 2016
    Fresno CA
    I was going to replace the slave master cylinder but i figured id try and bleed it first. I need help locating bleeding screw any advise would be greatly appreciated.
  2. #2 Re: How the bleed the clutch on a Getrag 284?
    most all you need to do is pump the living piss out of the clutch pedal.
  3. #3 Re: How the bleed the clutch on a Getrag 284?
    Dec 2014
    Can
    There is no bleed screw on the slave.
    Here's a good write up on how to bleed the clutch hydraulics.
    http://www.w-body.com/topic/51107-ge...dure/?hl=slave
  4. #4 Re: How the bleed the clutch on a Getrag 284?
    Oct 2016
    Fresno CA
    Thank you very much appreciate the help
  1. Bleed brakes
    By savage228 in forum Introductions/Noob Questions
    Last Post: 03-31-2016, 09:45 PM
  2. Getrag to an ls4?
    By barnettimpala in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 03-23-2013, 12:32 PM
