i got this 92 grand prix for my daughter that looks like new . it has 93000 miles and was a one owner car and she past away . i was told it had tranny probs but it was still worth what i gave for it .
this is what it does . put it in drive and you can feel it go in to gear . then you touch the gas and it slips ( so bad it just wont move ) and reverse is the same . there is a rocker switch that has start in 2nd gear . when i push it the car will move just fine . than i noticed that on the road it will stay in 2nd . switch it back to normal while your moving and it still stays in 2nd gear . after messin around with it for a while and it started working fine . i shut it off and started it back up put it in reverse and it backed up fine went to drive and it started to take off and it was like i shifted to neutral and went to slippin again . this car was takin care of and i just cant beleave this tranny is out . it only has 2nd gear and its the only gear that works right . please help![]()
