Thread: trans pan torque spec
Results 1 to 9 of 9
  1. #1 trans pan torque spec
    GT Level Member 91gpse's Avatar
    warren, mi
    anyone got the bolt pattern and torque spec for the trans pan on a 4t60 trans? i wanna change the trans fluid and filter.
  2. #2 Re: trans pan torque spec
    just make them pretty snug. not to tight, not loose.
    Thats what i do atleast.
  3. #3 Re: trans pan torque spec
    warren, mi
    id rather not risk have it leak all over the driveway... i got a torque wrench so why not take the extra 30 seconds to torque it down....
  4. #4 Re: trans pan torque spec
    I tried that with my LIM and broke a bolt off in the head.
    Go figure... grade 8 bolts will break with 17 ft lbs of torque...
    Lemme check "the book"...
    156 in-lbs
  5. #5 Re: trans pan torque spec
    Charles City, IA
    snug with a 1/4 ratchet I have done hundreds of pan drops and thats all i ever do.
    SMGPFC Two Nipple General
  6. #6 Re: trans pan torque spec
    Jersey
    uh oh. don't torque them down, i guarantee you strip your threads, they're aluminum, then you will really leak trans fluid all over the driveway. for tightening just do a star sequence like you do for your wheels with improvising.
    16' wrx sti- stock
  7. #7 Re: trans pan torque spec
    warren, mi
    156 in-lbs
    156 inch lbs for the trans pan? so 13ft/lbs... and actually your better off torqueing them... your less likely to strip the threads..... oh and reason the lim bolts broke is im guessing you didnt use new bolts did you? their torque to yield bolts you gotta replace them after you tighten them down if you dont they will break. same with cylinder head bolts.
  8. #8 Re: trans pan torque spec
    The torque spec is NOT TTY...
    Yeah, 156, use a small torque wrench if you must. Big one wouldn't accurate at that low setting (if it even has that setting)
  9. #9 Re: trans pan torque spec
    warren, mi
    i have an in/lb one ill just use that its good up to 240 in/lbs... or 20 ft/lbs.
  1. help i need a spec
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2010, 09:21 PM
  2. Spec-V
    By CTKGP09 in forum Track Sessions and Kills
    Last Post: 08-13-2009, 09:50 PM
  3. 98 GTP VS 03 Spec R Sentra
    By KawaFord in forum Track Sessions and Kills
    Last Post: 08-08-2009, 01:41 PM
  4. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
  5. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
