Thread: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
Results 1 to 20 of 23
  1. #1 how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    hangover park IL, in the garage working on one of 12 3800's
    gotta love Gm two different spellings for the same word...
    anyways getting reall close to firing up Al's Jyard hauler/DD
    (former) 2.8/125c car
    lots of small custom sh!7
    machine down 440T4 hall effect VSS housing to make a 3/16ths spacer to bolt the 125c mechanical speedo housing and gov shaft into the 440t4, worked perfect, even counterbored the 440 sliver to locate the 125c housing
    reworked (cut weld/spacer) broken rear mount to bolt to side pan of 440t4 (left it broken )
    removed rubber mount from front mount, cut and welded it solid since it was locate 1 inch farther forward.
    moved diff to engine bracket over to the other holes in the block, fit perfect, left 1 bolt out
    deleted pan sump for the trans ciculation pump that was used with it from when it was in the rear of the 442.
    put in the 2.8l/125c TV cable
    rework trans cooler lines from 442 install to work with D side radiator fittings
    rewired 440t4 5 wire round connector to the 125c's harness
    now lets see how the great rig fest turns out...
    X yer fingers folks, smoke test's comming up...
  2. #2 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    Oklahoma
    Good Lord, thats some rigging there now.
  3. #3 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    have pics too!...
    soon....
  4. #4 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    I live here. UR LOSN's Avatar
    Rockford, IL
  5. #5 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    heheh i have something fer ya....
    i'll give ya a hint...its specifically made for BIG injectors on max effort 3800's
  6. #6 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    Hoffman/Schaumburg, IL
    jeez I just left and your already on here posting
  7. #7 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    Quote Originally Posted by 02BlueGT View Post
    no rest fer the wicked
    next time i'll put you to work
  8. #8 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    yeah, I cycled the steering wheel
  9. #9 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    we had used the 440T4 inner tulip (plunge joint) and axle shaft with the 125c/ciera outter CV for the drivers side, on the passenger side we used the 125c/ciera outter CV and the shaft with the 440t4 inner tulip
    worked great till the test drive...the passenger axle despite using the shorter 125c shaft was too long on left turns the inner tripod/plunge joint would bottom out...removing the axle nuts confirmed this with the car on the ground...i was able to compress the drivers side over an inch...the passenger side budged MAYBE an 1/8th of an inch...
    have a new 88 ciera 2.8/440t4 shaft (64$ with the JA8 brakes) on the way...
    total cost for swap.... <180$ (and i shouldnt be counting the PM items but i did) a new CPS, just cause its a ***** in car...new spark plug wires, and a little hose...
    we did get all 4 gears on the test drive before we parked it due to the axle issue...
    BTW the welded mounts make it idle like a lumpy cam lol
  10. #10 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    it was funny messin with ya lol just remember we made Al's wife amanda do the same thing...but with the tires on the ground now that was funny....
    PICS!
    the death of the 125c...drove it to my place with 1st gear only, its now torn apart and the alum&case is in my scrap pile
    mech speedo drive for the 125c on left, 440T4 VSS on the right
    millled down the 440t4 housing to act as the 3/16ths spacer for the 125 mech housing ...hey the speedo works!
    the whole shebang hooked up
    Reworked rear mount
    welded front trans mount
    reworked the 440t4 cable bracket for the longer 125c cable...hey it works lol
    purdy aint she? (the whole car has ~500$ in it and has been beaten to death and comes back fer more ...)
    left to right, Al, Dave (02bluegt), Dennis (DoubleD99GS) my fatass is hiding behind the camera lol
    Al lounging around...gotta love how cheap this car is...heater core was 20$, blower motor was 14$ the RF axle costs 64$
    the best Jyard beater around...now we just need a few different colored doors
  11. #11 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    PICS!
    I really wonder what was going through my head, cause I sure do have a funny look on my face....Everyone notice how clean Denis and my hands are, We were "Supervising"
  12. #12 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    Oklahoma
    someone needs to give me that collapsible cherry picker.
  13. #13 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    Barksdale AFB, LA
    Lol @ the tranny pan magnet.
    2009 Subaru Impreza WRX STI
  14. #14 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    lots of funny shleib that night lol
    you can pry it outta our cold dead hands
    it was an AC Delco hoist and engine stand that Al's wife bought him as a wedding (funeral for us bachelors) present. she got it from autozone, i dont know if they still make or carry it but it's deffinatly worth it... much better made than the HF cheapo's.
    yeah the magnet looks like DD's old mohawk
  15. #15 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    Oklahoma
    Quote Originally Posted by turbocharged406sbc View Post
    I asked my wife just before we got married if she had ever saw the movie Four Weddings and a Funeral. She said no. I said dont bother, it was five of the same thing.
    Ive been in the dog house ever since.
  16. #16 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    lol
  17. #17 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    ^^^ Nice
  18. #18 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    should update this... put in new Pass side axle (was almost 2 1/2 in shorter) and al drove it for 4 days no problem all 4 gears...now we suddenly have only 1 & 2nd, 3rd is just neutral (damnit!) i've gotta go over the diagram and check further into the 90 440t4's 2nd,3rd,4th gear switches see if i missed something the 90 has that the 88 440t4 wouldnt (other than 2nd gear switch)
    the 2.8L/125c ECM only has TCC... we may have to run a 2.8L/440t4 ECM/EPROM
  19. #19 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    SE Level Member Sinister Drag Designs's Avatar
    wouldnt it of just been easier to buy a Ford
  20. #20 Re: how to shove a 90 440t4 in place of a 88 125c in a POS 88 cutty ciera
    thats just asking fer lady luck to pee in my cheerios
    btw the new drill bit turned out 1 perfect FPR housing... i may be taking it back to dress the FRP shoulder dia smaller for better fitment of the retainer screws...
    ...but yes houston we can weld the FPR housing to the front rail allowing for OE vac lines and simplified plumbing.... i also have the FPR housing at 1 inch of length for the weldon sets (prob shouldnt have cut all those blanks from the barstock...ohwell)
    didja talk to john about that tapping machine?
  1. Best place to buy tires?
    By scoobyydooooooo in forum Tires & Wheels
    Last Post: 04-15-2008, 07:08 PM
  2. 125C buildups and tech help
    By Trannyman95 in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 03-13-2008, 01:51 AM
  3. This place is slow
    By Preotic in forum Forum Bugs/Suggestions
    Last Post: 02-08-2008, 01:59 AM
